    Perimeter Seam. Why stops hotend on end and/or start
    • peterfrostaundefined
      peterfrosta
      Duet Wifi
      Tronxy X5SA 400x400mm
      bowden drived Hotend (BigBooster H2O)
      S3D
      I have problems long time with blobs on start and or stop on each periemter.
      It results in visible and touchable seam on outershell.
      I tried nearly all combinations ( 😉 ) of retraction, restartretraction, coasting, etc... combined with diffenrent sets of linear compreassion. Printed a lot test "towers".
      I noted the "best" seam result on layers with NO retraction (all retraction settings disabled).
      I noted that activating any retraction settings (even just coasting activated) result in short stops from the hotend at start and especially at the end of perimeter. in this time the blobs are created.
      That's the reason why the prints with no retraction result in better outlines - better seam.
      Since the seam ist still far away from perfect, i would like to pimp them with the retraction settings. Unfortunately, these settings make the result worse as i tried to describe above.
      The one solution i could imagine is to accelerate the extruder. But i think my speed settings in config should be fast enought - if not even to fast.
      Or is the Z to slow maybe?
      M201 X2500 Y2500 Z3000 E3000 ; set accelerations (mm/s^2)
      M203 X24000 Y24000 Z3000 E6000 ; set maximum speeds (mm/min)
      M566 X550 Y500 Z1000 E1000 ; Jerk (mm/min)
      Some good ideas?
      • Vetiundefined
        Veti
        print your config.
        maybe you forgot to configure your thermistors correctly and are printing at the wrong temperature.
          peterfrosta
          thx i will do immediately.
          pls dont blame me about my confused config
            peterfrosta
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 14:46:51 GMT+0100 (Mitteleuropäische Normalzeit)
            M550 P"Tronxy" ; set printer name
            M667 S1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S1 ; enable FTP
            M586 P2 S1 ; enable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P2 S1 ; physical drive 2 goes forwards Z1
            M569 P3 S0 ; physical drive 3 goes backwards
            M569 P4 S1 ; physical drive 3 goes forwards Z2
            ; DUAL Z
            M584 X0 Y1 Z2:4 E3 ; set drive mapping ;M584 X0 Y1 Z2 E3
            M671 X-90:490 Y200:200 S4 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            M350 X64 Y64 Z64 E64 I1 ; configure microstepping with interpolation
            ;M92 X323.835 Y320 Z1606.522 E1582 ; set steps per mm
            M92 X322.381 Y320.320 Z1606.522 E1582 ; set steps per mm
            M572 D0 S0.5
            M906 X1100 Y1100 Z1000 E1200 I35 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-7 Y-14 Z0 S1 ; set axis minima
            M208 X400 Y360 Z390 S0 ; set axis maxima
            M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            ; Filament sensor
            M591 P1 C"e0_stop" S1 ;
            M558 P8 C"zprobe.in+zprobe.mod" H2 F2000 T12000 S0.04 I1 ; set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X-30 Y5 ; set Z probe trigger value, offset and trigger height Z WERT in homeZ.conf
            ;M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
            ;M557 X52:350 Y30:350 S20 ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T102400 B4138 ; configure sensor 0 as thermistor on pin bedtemp
            M307 H0 A106.4 C953.3 D2.2 V24.1
            M140 S65 R40;
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M307 H1 A1170.9 C396.6 D5.8 V24.1
            M950 F0 C"fan0" Q400 ; create fan 0 on pin fan0 and set its frequency
            M563 P0 D0 H1 F0:1 ; define tool 0
            G10 P0 R180 S200 ; set initial tool 0 active and standby temperatures to 0C
            ; Custom settings
            ;Tappering
            M376 H10 ; Bettkompensation läuft ßber 10mm Linear aus
            M501;
