e3d toolchanger Pause t0,1 right pocket for ooze 2,3 lef
i have all set up and tuned in and i am happy with my E3d tool changer. Now i switched the 2 right tools with hermea , they have the nozzle so far left that it can't reach the left (standard) ooze bucket (which i reused from my big box ) so i mounted one another ooze box to the right side.Problem is when you hit pause it crashes the hermea in the printer because it is much wider than the bowden v6
i know there is in V3 of the firmware an conditional G code for a macro.i would need to call an parking macro which asks tool number and if 0,1 it calls parkleft.g macro and if 2,3 it calls park right macro ?
And being now verry happy i would love to avoid upgrading to v3 of software ?
i also spent a lot of time dialing in the IR probe (thank dc42 )
so if someone has an hint i would be happythx thomas
RRF3 isn't so bad really.
There are even some example config sets using RRF3 to compare against.
https://github.com/Duet3D/RRF-machine-config-files/tree/master/E3D_Tool_Changer
