Duet3 Mainboard CNC Mill
I'm glad you find Duets meet your needs!
There is a preview of the CNC version of DWC at https://github.com/Duet3D/DWC-CNC/releases.
Sweet! In good time for the holidays, I hope I get to play with this a little!
Hi all,
I have been working on the CNC dashboard. Please feel free to leave some feedback on ideas and enhancements. Also, if you are a CNC user I have a couple plugins that I have written that may add some nice/wanted functionality
https://github.com/Sindarius/DWC_GamepadJogger_Plugin
Adds the ability to use a gamepad to jog your spindleand
https://github.com/Sindarius/DWC_GCodeViewer_Plugin
Will let you get a visual of your gcode, I recommend sticking to wire mode for CNC gcode. Just recently finished adding G2&3 support. -
@dc42 This looks excellent, i have only just started with duet3d and so far I'm impressed.
I've created a discussion thread for the DWC preview in the CNC forum.
https://forum.duet3d.com/topic/20416/preview-version-of-cnc-optimized-dwc
I got my mill up and running on my Duet3 with the Workbee version of DWC.
What is the best post processing option from Fusion360 to use with Duet?
@Shanian79 i would use the workbee post processor.
haven't seen any others about.
Theres a modified version about as well that allows the spindle to be controlled through gcode
http://www.makergeek.co.uk/makergeek/2019/8/3/improved-duet3d-fusion-360-post-processor-for-ooznest-ox -
@Shanian79 did you have to do much to get it working?
@R4ffers No not really. 10x simpler than setting up a printer. Just setting up the config and wiring up the steppers is all it really took. I set it up with sensor-less homing, which I haven’t done before. That took me a little over an hour to get figured out dialed in. Overall it’s really simple for a 3 axis.
The workbee DWC is very simple and straight forward.
@Shanian79 excellent well done. I've just finished building a CNC router using ooznest ox plates. I'm currently using grbl on a protoneer pi hat but have finally made the plunge and bought the duet 3 m6hc. I have made a test bed and installed endstops and steppers with a dual y axis, got things to finally start and stop last night. Been a big learning curve.
@dc42 said in Duet3 Mainboard CNC Mill:
Sounds like progress towards CNC use!
Can it work on duet2 wifi?
Can it work without needing the fake printer things, like extruders?
Thanks!
@tenaja yes, it works on the duet 2.
Just make sure you use M453 to set the machine in CNC mode -
@tenaja said in Duet3 Mainboard CNC Mill:
yes
thats just a RRF thing, not DWC, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_Select_CNC_Device_Mode
