Duet2 WiFi Firmware on Raise 3d E2 ?
yes so the printer starts.
@Proschi78 said in
this is befor updatingDuet2 WiFi Firmware on Raise 3d E2 ?:
(>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DLM-996RU-N8PS4-7J1D8-3SJ6N-1B9BR<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25536<LF>Dynamic ram: 99000 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6280<LF>Tasks: HEAT(blocked,1232) MAIN(running,3828) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:40 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6224 bytes (slot 0)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 18.7, current 23.2, max 23.4<LF>Supply voltage: min 0.0, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
yes, but my statement was, the firmware was updated to 3.0.
there are config changes you need to do as the rrf2 config does not work with rrf3.
without those changes you wont be able to move anything.
I'll keep trying tomorrow, thank you
the main problem now is that the printer doesn't start anymore.
by start I mean that the display no longer starts up in the menu.
it doesn't finish loading -
@Proschi78 i guess you need to go back to 2.02 then
@jay_s_uk that's exactly what I tried.
it just didn't work out.
the board stays at 3.0 -
@Proschi78
that might be a price to pay for running the original firmware on the raise 3d -
@Veti but unfortunately he no longer plays the original firmware on the board via the printer
not sure what you mean
@Veti https://support.raise3d.com/E2/how-to-update-the-motion-controller-firmware-20-1143.html
The printer does not do the firmware update because the board is flashed to 3.0
@Proschi78
yes but the firmware updated to 3.0. that is what you wanted to do in the first place.
a lcd screen is not necessary for the operation of a duet. -
@Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
a lcd screen is not necessary for the operation of a duet.in my case it does
the WiFi module sits on the display controller -
@Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
in my case it does
the WiFi module sits on the display controllerwell you might want to change the eol and line settings in yat so that you can see the actual status of the wifi module.
i can only connect the motion board via usb.
the display controller is also operated via this interface -
they can easily just route the spi lines to the display.
that is why the full M122 output is relevant.
you probably did not update the wifi firmware when you updated to the rrf3 firmware. -
you probably did not update the wifi firmware when you updated to the rrf3 firmware.I cannot update the WiFi firmware.
because the wifi module is on a different board.
and I have no access to it via the pc -
the wifi firmware is not updated via the pc.
see
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmwarebut the M122 output is important
@jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
iap4e.bin
did you rename it to Duet2combinesIAP.bin like the error message says?
Duet2CombinedIAP is not the same as iap4e.bin! Renaming it will not work. You can get Duet2CombinedIAP.bin from one of the RRF 3.x releases.
@dc42 can I go back from V3.0 to V2.02 that easily?
@Proschi78 that'll be why the downgrade didn't work then.
use the IAP file dc42 linked to and the firmware from my google drive -
@jay_s_uk ok i will try today at noon
Hello everyone here who helped me. I was able to successfully install a version that was before 2.02. Then the printer could be updated via the Raise software. The whole thing was worth it for me, because now I have the possibility to control it via octoprint for whatever reason. thank you again
Do you think an original duet2 Wifi would work with the hardware components?
@Proschi78
not with the display, but you only did a third of the firmware update of rrf3. it might be that you could update the board to 3.1.1
