    Tool Distribution Board RJ11 cable
    306
    • warpsterundefined
      warpster
      First can someone tell me if the RJ11 cable that goes between the Duet 3 and the Tool Distribution Board has always shipped with the Tool Distribution Board? The reason I ask is because I ordered my Duet 3, Tool Distribution Board, and ToolBoard at the same time form Filastruder but I did not get The RJ11 cable. Everything was put in one box so I didn't know if it just got missed or not. I ordered in July but then ended up in the hospital for a month plus recovery etc. and just got back to it. So I asked Filastruder but they didn't know if they ever shipped without. I thought they might just send me one but they didn't.
      So I need to know the specs on it. Is it straight thru as in pin 1 to 1 , 2 to 2 etc or crossed end to end?
      Thanks
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • A Former User?
        A Former User
        straight through; and you'l have to ask fillastruder about accessories as that can vary from reseller to reseller afaik; given the amount of questions on which cable to use I'd put my money on no-one getting the cable with the board.
        warpsterundefined 1 Reply Last reply Reply Quote 0
        • warpsterundefined
          warpster @A Former User
          @bearer All of the listings for it say it is included. I just didn't know if it has always been included. Thanks for the straight thru info . That's what I thought from looking at the wiring diagrams.
          One other question, how many wires does it need? All 6, 4 ?
          Does anyone know a good cable to order that is short? I ordered one from Amazon that I thought was straight thru but it isn't...hard to know for sure from Amazons description if they are straight thru.
          jay_s_ukundefined A Former User? 2 Replies Last reply Reply Quote 0
            jay_s_uk @warpster
            @warpster high speed ADSL cables on the ones to go for.
            • warpsterundefined
              warpster @jay_s_uk
              @jay_s_uk Where do I find a short one and 4 wire or 6?
              • JuJuDeltaundefined
                JuJuDelta
                I got a load of these and they work. Nice and cheap.
                1mtr long, just coiled up the excess.
                CAN-FD on the duet uses the two center wires, 1:1, no cross over.
                https://cpc.farnell.com/unbranded/88bt-101/modem-lead-rj11-6p4c-1m-white/dp/TE07752?CMP=i-ddd7-00001003#
                T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                • A Former User?
                  A Former User @warpster
                  @warpster said in Tool Distribution Board RJ11 cable:
                  Can you please show the listings where it says its included ?
                  I have more than a few Duet-3's and various tool boards and never had a RJ11 socketed cable shipped with it ever, just make/crimp your own its simple.
                  for the LC-1 direct from the Duet-3 all you need is wires 3 & 4 connected and a resistor between 1 & 2
                  • Stephen6309undefined
                    Stephen6309 @warpster
                    @warpster The RJ11 cable came with mine when I ordered from Filastruder.
