Duet 2 wifi RRF2.5 to RRF3 DC42 probe?
Hi all
Had a DUET 2 wifi on my cartesian i3steel for a few years and its working fine
Having read a bit here and there i'd like to try the latest RRF3 ( always trying to get the best out of my hardware) I understand the upgrade process version to version
Where im struggling is how to implement my DC42 IR sensorMy 2.05 config is
; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P1 H3 F300 T3000 ; Set Z probe type to modulated and the dive height + speeds G31 P500 X30 Y-10 Z0.55 ; Set Z probe trigger value, offset and trigger height Bigger Z value = lower nozzle (55 rough/45 smooth) M557 X30:190 Y20:180 S40 ; Define mesh grid
The 3.0 config generated by the configurator is
; Z-Probe M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X30 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X30:190 Y20:180 S40 ; define mesh grid
Im not at all comfortable with the new notation yet but the "set Z probe type to unmodulated " comment seems odd.
Would appreciate some help
Thanks in advance
@Phil-Maddox said in Duet 2 wifi RRF2.5 to RRF3 DC42 probe?:
the probe only needs zprobe.in
change to
M558 P1 C"zprobe.in" H5 F120 T6000
@Phil-Maddox On my Deut 2 I have:
M558 P8 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to digital and the dive height + speedsThat sets the IR sensor to digital mode.
Plug into Z probe connector, signal to Z_Probe_IN. Power is from the connector, also.
Thank you both for the prompt reply and info. Much appreciatted
