Duet 3 6SH or Mini, shall I get a PanelDuo?
I'm looking to get into the Duet eco-system with either the Duet 3 6CH & SBC or the new Mini.
I've tried to read up on the PanelDuo but thought I should just ask instead. Some places say to use a touch screen hooked up the the SBC/RPi instead of using a PanelDuo. What's the pros and cons?
Is the PanelDue "direct" linked to the Duet or does it use the web interface?
What setup would you recommend?
@Reine said in Duet 3 6SH or Mini, shall I get a PanelDuo?:
its direct. communicates via uart serial.
it depends on your need, i.e how often do you want to control the printer directly while standing in from of it.
never: use the web interface.
once a month: use the web interface and use a mobile/tablet for the direct connection.
every day. get one.regarding pi or paneldue. if you decide to go without the pi, then paneldue gives you the better fallback.
Hi . I look at it like this. It is better to have a device thats dedicated to the task rather than an all purpose device you have to manipulate into doing what you want
Like yourself , i bought into the Duet RRF ecosystem 4 years ago and while the components were expensive at the time there were very few 32 bit alternatives
Having used BTT SKR1.3 Makerbase 32 bit boards , Lerdge boards and more recently a Chitu board i would still highly recommend the Duet boards purely for the quality components and build.
( i do a lot of printer repairs / upgrades / testing so thats why ive used most 32 bit boards available)AT the time of ordering my Duet2Wifi i also ordered a PanelDue 4.3 and ive never looked back.
Unlike Veti, i do a lot of printing via the web interface . However for testing / adjusting the Z offset as well as using the pause / change filament function the Panel Due is great to haveGood luck
i'm new to duet also . i think i could get along without paneldue . yes its a direct connection , but its not the same as the web interface .
imho its much better to use a dedicated tablet that will sit near the printer . you'll get better screen , better resolution , scrolling ability and better touch .
and you can get a tablet for almost the same price .
Btw you cannot use the sd card of the PanelDue with the Duet 3 (6HC, not sure about 5LC).
I find any interface attached to that printer most useful as "read only" i.e. viewing status. Controlling or printing i prefer to do from a larger interface.
You can use the PanelDue SD card socket when the PanelDue is connected to a Duet 3 Mini. It's likely that we will add this facility to the firmware for Duet 3 next year, however the Duet 3 does not have a ribbon cable connector for PanelDue, so the wiring would be complicated.
