    Problem with config working with Simplify on the Tool heater
    Config Tool
    509
    • Work Horse XLundefined
      Work Horse XL
      Hello guys. I am new to this 3D printing and I'm having trouble with my printer g-code. I'm using simplify 3d. When I make a print file from simplify and send it to the printer using DWC it give me errors 104 invalid tool number, 109 invalid tool number. The bed heater turns on and sets temp as instructed and waits. The tool does not.
      Here is my config file. Not sure what I have wrong. Thank you
      Using firmware 3.1.1 and pi
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 17:27:13 GMT-0600 (Central Standard Time)
      M550 P"Duet 3" ; set printer name
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M569 P0.5 S0 ; physical drive 0.5 goes forwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M584 X0.0 Y0.2 Z0.3 E0.5:0.4:0.1 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X64.05 Y64.05 Z800.00 E400.00:800.00:65.00 ; set steps per mm
      M566 X300.00 Y300.00 Z24.00 E300.00:24.00:300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z300.00 E1200.00:300.00:18000.00 ; set maximum speeds (mm/min)
      M201 X700.00 Y700.00 Z100.00 E250.00:100.00:700.00 ; set accelerations (mm/s^2)
      M906 X2800 Y2800 Z2800 E800:2800:2800 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X625 Y711 Z515 S0 ; set axis maxima
      M574 X1 S1 P"io1.in+io2.in" ; configure active-high endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io3.in" ; configure active-high endstop for low end on Y via pin io2.in
      M574 Z1 S1 P"io4.in+io5.in" ; configure active-high endstop for low end on Z via pin io4.in
      M558 P8 C"!^io7.in" H5 F520 T7200 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X2.8 Y22.8 Z4 ; set Z probe trigger value, offset and trigger height
      M557 X10:580 Y10:700 S40 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T94400 B4055 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 B1 S1.5 ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
      M106 P3 S1 H-1 ; set fan 3 value. Thermostatic control is turned off
      M950 F4 C"out8" Q500 ; create fan 4 on pin out8 and set its frequency
      M106 P4 S1 H-1 ; set fan 4 value. Thermostatic control is turned off
      M950 F5 C"out9" Q500 ; create fan 5 on pin out9 and set its frequency
      M106 P5 S1 H-1 ; set fan 5 value. Thermostatic control is turned off
      M950 F6 C"out3" Q500 ; create fan 6 on pin out3 and set its frequency
      M106 P6 S1 H1 T50 ; set fan 6 value. Thermostatic control is turned on
      M563 P0 S"Hot End" D0 H1 F6 ; define tool 0
      ; Custom settings
      M584 X0:1 Y2 Z3:4 E5 ; assign stepper motor channels
      M591 D0 P7 C" io8.in" S1 R40:120 L6.325 E7.0 ; Duet3D plus-generating sensor for extruder drive 0 is connected to pin io7.in endstop input, enabled, sensitivity 6.rev, 40% to 120% tolerance, 7 mm detection length
      M591 D0 ; display filament sensor parameters for extruder drive 0
      T0 ; select first tool
      arhiundefined 1 Reply Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt
        Post the first part of the S3D file that includes the first tool reference.
          Work Horse XL
          This is showing T1 but in the software I have it set a T0 not sure what's up with that but maybe this is the issue?
          On my FFF settings page in advanced under Extruder 1 Toolhead
          overview toolhead index is Tool 0
          Thank you
          G90
          M82
          M106 S255
          M140 S50
          M190 S50
          M104 S200 T1
          M109 S200 T1
          G28 ; home all axes
          ; process Process1
          ; layer 1, Z = 0.200
          T0
          G92 E0.0000
          G1 E-5.0000 F1800
          ; feature skirt
          ; tool H0.200 W0.400
          G1 Z0.200 F1002
          G1 X254.582 Y264.303 F4800
          G1 E0.0000 F1800
          G92 E0.0000
          G1 X256.222 Y262.811 E0.0737 F1800
          G1 X256.803 Y262.424 E0.0970
          G1 X258.710 Y261.536 E0.1669
            Work Horse XL
            I’m guessing the T1 is the port the sensor is on after thinking about it.
            • fcwiltundefined
              fcwilt @Work Horse XL
              @Work-Horse-XL said in Problem with config working with Simplify on the Tool heater:
              No, it's the tool number which likely should be T0.
                Work Horse XL
                I’m not sure why it’s choosing T1 when I have it Tool 0 in the settings. Have you ever seen that?
                Thank you
                • arhiundefined
                  arhi @Work Horse XL
                  That's your problem right there, using a dead software 😈
                  Are you at least using latest 4.1.2 as previous had a lot more issues with dual head?
                  M104 S200 T1
                  M109 S200 T1
                  Do you have dual extruder configured? Check how you configured it. Looks like you set main extruder to be T1 but then set T0 to be used from process1. Did you do it manually or you went through dual extrusion wizard?
                  What's in your start code?
                  ; process Process1
                  T0
                  I see that for process1 it selects T0 but only after the process started, how many processes you have here?
                  p.s. strongly suggest you check out ideaMaker, it is the slicer that looks like simplify3d more than any other slicer but is much better and more powerful than simplify3d. took me a very short time to get accustomed to it after years of using s3d
                  Work Horse XLundefined 1 Reply Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt
                    The problem is not S3D.
                    I have used S3D since early on and it works fine.
                    If it is including a reference to T1 it is because there is something wrong in the S3D settings put in place by the user.
                    Work Horse XLundefined 1 Reply Last reply Reply Quote 1
                      Work Horse XL @arhi
                      @arhi it’s just a single extruder. Not sure on the process. I’m just getting stared. It seems to be working fine for me if I can just get this part fixed. It’s the newest version of s3d
                      Thank you
                        Work Horse XL @fcwilt
                        @fcwilt I’m sure that’s the issue but I can seem to find the problem. I might try to start over with a clean install.
                        Thank you
                        • arhiundefined
                          arhi @Work Horse XL
                          @Work-Horse-XL send the factory file up there on the forum as they asked, that's fastest way to see what you messed up. S3D will not use T1 unless you configured dual extruder machine, you might go through the configuration wizard from scratch
                          • baird1faundefined
                            baird1fa
                            You have configured simplify3D to use T1 for the hotend rather than T0. And your config.g hasn’t been configured to recognize tool 1
                              Work Horse XL
                              I used the wizard to do a new profile and it fixed the issues it looks like. I need to test it but the g code is coming out correctly now.
                              Thank you guys.
                              • Vetiundefined
                                Veti
                                M584
                                as a side note observe the order
                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                                M584 must come earlier in config.g than any M350 and M906 commands. If it creates new axes, it must also be earlier than any M92, M201, M203, M208, M350, M566, M574, M667 and M669 commands.
