3.2 RC1 - DWC not saving file - Mobile view
Running 3.2 RC1 on a duet 3 in standalone mode.
DWC is also 3.2 RC1.I can successfully edit a macro when accessing the file through a desktop.
When accessing the same file through a mobile device and making a change, when save is pressed it says that the file is successfully saved but when the macro is reopened, the edit has not been saved. -
Can you please share some more details? What phone and browser are you using? Is that macro file in /sys or /macros?
@chrishamm
I am running android 11 using chrome as the browser (just the standard release version).
The macro file is in /macros.
This is the macro, nothing special. I was adjusting the S value for the stall detection.; Engage the toolchanger lock M400 ; Make sure everything has stopped before we make changes ; ################## Prepare Axis ######################### M584 P4 ; Unhides U axis ; ################## Endstop Mapping ###################### M574 U2 S3 ; set U axis (tool changer) maxima to use motor stall ;################### Stall Detection ###################### M915 U S3 F0 H200 R4700 ; Coupler ;################### Locking Procedure #################### G91 ; Use relative positioning G1 H1 U180 F5000 ; Move all carriages up 700mm, stopping at the endstops G90 ; Back to absolute positioning ; ################## Reset System ######################### M584 P3 ; Hides U axis -
rebooted and the issue has gone. Just seemed very odd that one client could edit it but the other couldn't. Will keep an eye on it
Had the Same Problem. You need to wait some Seconds or make a "enter" keystroke.
Thanks, I could confirm this. It looks like the editor used for syntax highlighting doesn't support touch so I'll leave it disabled for touchscreens in v3.2. I'll check if I can upgrade it as part of v3.3.
