Kossel Mini & Duet-wifi
Hi there,
My batch 3 duet-wifi arrived last week and finally i had the time to fire up the old kossel mini.
i built the kossel for almost 6 months using ramps and getting crappy-at-best results.after taking everything apart and reassembling and the new duet, i got it working amazing !!! in one day.
few thing i came up with:
1. from time to time i get a fault on the hot-end heater saying it takes too long to heat (original e3d-v6)
2. i cant find a decent part cooling model that can work with the "mini differential ir probe"
i want to put a strong cooling (2 x 40mm blowers) and it seems no one mixed a good solution with a place for the ir probe
unfortunately i am not a strong modeler..
Glad it's working well. We get decent results with this mount on a v6, it only has 1 40mm print cooling fan though. Might tide you over until you find one with two print cooling fans:
https://github.com/T3P3/kossel/blob/master/Release3/STLs/R3-Hotend_fan_ir_e3dv6-v2.2.stl
Cheers
Tony
Hi ttl64, to get rid of the heater faults, see https://duet3d.com/wiki/Tuning_the_heater_temperature_control.
HTH David
HTH David
