    Pause.g Resume.g problems
    Gcode meta commands
    8
    58
    3.7k
    • Deluxe 600undefined
      Deluxe 600 @dc42
      @dc42 Its set by the Slicer. So no ideas? Ow man 😞
        Deluxe 600
        Well didnt know this would be such a problem
          an you share a sample gcode file? What slicer?
          Deluxe 600undefined 1 Reply Last reply Reply Quote 0
            Deluxe 600 @Phaedrux
            @Phaedrux Hi.
            Im using PrusaSlicer for slicing.
            Here is a gcode i tried printing.
            test 1_0.3mm_PLA_MK3.gcode
              So basically it turns the fan on with M106 S255 and leaves it on a full power for the duration of the print and then turns it off at the end.
              If that's normally the case, as a work around, why not just set the fan speed to 100% in resume.g?
                Now that 3.2 is released can you test with that?
                  Deluxe 600
                  It is S255 for PLA but once you start printing PETG the speed changes how its needed. No i havent tried 3.2 yet. Could it solve this problem?
                    Phaedrux Moderator @Deluxe 600
                    @Deluxe-600 said in Pause.g Resume.g problems:
                    I don't know, but testing on the most recent code base would be ideal in case it has been solved and any work to fix it if it is a bug would happen there. Since you're on 3.1.1 it's an easy update by uploading the Duet2and3CombinedFirmware zip file to the system tab.
                      @Phaedrux Hi.
                      So i have updated to 3.2 and tried the pause.g with M107 and also with M106 S0 and the resume.g with M106 R1 and also with M106 R2 but still no luck. Seems like the M106 R1 command sets the speed always to 0rpm. Thank you guys for helping.
                        Deluxe 600
                        I think its a bug in the software. There is no reason why should this not work, you guys dont use pause on your printers? I went trough every forum i could find and the M106 R1 command should turn the print fan back on...but it doesnt for unknown reason.
                          Your gcode all looks ok, so it may be a bug. We're looking into it.
                            @Phaedrux Thank you. Meanwhile i will try to figure it out, if i find any way to solve this problem i will let you know.
                              I have just tested that on my delta running 3.2 and it works properly for me.
                              Pause.g:
                              ; Pause macro file
                              if state.currentTool != -1
                                M83					; relative extruder moves
                                G1 E-4 F2500		; retract 4mm
                              G91					; relative moves
                              G1 Z5 F5000			; raise nozzle 2mm
                              G90					; absolute moves
                              G1 X0 Y85 F10000
                              M106 S0
                              Resume.g:
                              ; Resume macro file
                              M106 R1
                              G1 R1 X0 Y0 Z2 F5000	; move to 2mm above resume point
                              G1 R1 X0 Y0 Z0		; lower nozzle to resume point
                                G1 E4 F2500		; undo the retraction
                              The GCode file I am printing uses M106 S0 at the start, M106 S255 at the start of the second layer, and M106 S0 at the end. My M563 command in config.g does not have a F parameter.
                                Deluxe 600 @dc42
                                @dc42 said in Pause.g Resume.g problems:
                                if state.currentTool != -1 M83 ; relative extruder moves G1 E-4 F2500 ; retract 4mm G91 ; relative moves G1 Z5 F5000 ; raise nozzle 2mm G90 ; absolute moves G1 X0 Y85 F10000 M106 S0
                                Ok...so i have found out what was the problem with the FAN. I cant believe it was this trivial, any way the only reason the FAN didnt start up on resume was that the M106 R1 has to always be on the first place otherwise it just doesnt work. When i found out it was this all along i was happy and mad at the same time. Thank you all for your help we finaly did manage to get it working. Have a great day
                                fcwiltundefined 1 Reply Last reply Reply Quote 1
                                • fcwiltundefined
                                  fcwilt @Deluxe 600
                                  Do you mean the first line in the file?
                                  Thanks.
                                    Deluxe 600 @fcwilt
                                    @fcwilt Yes the very first line in the file.
                                    • fcwiltundefined
                                      fcwilt @Deluxe 600
                                      That seems very odd.
                                      Thanks.
