E3D BigBox rebuild - some issues - Duet Wifi
Hi all,
As you may have noticed, I've restarted my E3D BigBox again.
This has been fully disassembled, cleaned rewired and rebuild.
Now I have some issues (after the SD Card issue)- Z axis only move in 1 direction, no matter what Direction I push. What may case this,
- Currently running v 1.19.2, do I stay here, or do I move to another version, and if so, what version would that be.
- While troubleshooting, I have pushed the reset button on my 7" PanelDue. How to get that fixed, keep in mind, I'm sure this has a direct impact on the version running.
Most probably other issues might appear, I'll open another post for those once I get to them.
Thx in advance
T.
@TimV said in E3D BigBox rebuild - some issues - Duet Wifi:
most likely a bad crimp contact.
if you are starting from scratch go for 3.1.1.
Since you need to do an bossa update for your paneldue go the bossa route.
see
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3While troubleshooting, I have pushed the reset button on my 7" PanelDue. How to get that fixed, keep in mind, I'm sure this has a direct impact on the version running.
Small update:
- Z axis work, confirmed was a bad cable connection, easy fix.
- Flashed PanelDue with 1.2.4 and also ran the verify. All is ok. Bossa port appears etc. But still nothing after fully reconnecting it back to the DuetWifi.
- Didn't yet do the upgrade to 3.1.1, avoid multiplying the issues.
So, any advice on how to troubleshoot what's wrong with the PanelDue.
I hear no beepbeep when the DuetWifi boots (or has finished booting), I have 5v in the pinout, and also 3,3 between GND and 3.3V on the Panel Due V2.0 mini board. and also on JP1 (Gnd and 3.3V pin).
Cable between DuetWifi and PanelDue has been checked and confirmed correct and working.Thx
T.
@TimV In config.g, you do have M575 P1 S1 B57600 ?
The paneldue doesn't beep when the printer boots, unless you've coded that in config.g.
At least update to 2.05.1. Here are some instructions to update from such an old firmware.
https://forum.duet3d.com/topic/18962/firmware-not-updating?_=1609006045448
