UNSOLVED 3.2RC2 - Hotend faulting but no console message
One of my heaters is faulting. Usually, there is message stating why (e.g. temperature rising slower than expected), but in this instance, nothing is being displayed.
I only have one tab open for the machine as can be seen in the HTTP sessions=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-RC2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6JTD4-3S86S-KV92S Used output buffers: 1 of 40 (25 max) === RTOS === Static ram: 149788 Dynamic ram: 94388 of which 120 recycled Never used RAM 114536, free system stack 128 words Tasks: NETWORK(ready,189) ETHERNET(blocked,109) HEAT(blocked,271) CanReceiv(blocked,834) CanSender(blocked,348) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1101) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:09:48 ago, cause: software Last software reset at 2020-12-26 18:41, reason: User, GCodes spinning, available RAM 114652, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 41.2, current 41.4, max 41.5 Supply voltage: min 26.7, current 26.8, max 26.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 33930, standstill, reads 40890, writes 0 timeouts 0, SG min/max 0/140 Driver 1: position -9510, standstill, reads 40890, writes 0 timeouts 0, SG min/max 0/132 Driver 2: position 12561, standstill, reads 40888, writes 2 timeouts 0, SG min/max 43/1023 Driver 3: position 8832, standstill, reads 40890, writes 0 timeouts 0, SG min/max 0/304 Driver 4: position 0, standstill, reads 40890, writes 0 timeouts 0, SG min/max 0/286 Driver 5: position 0, standstill, reads 40890, writes 0 timeouts 0, SG min/max 0/269 Date/time: 2020-12-26 18:51:23 Slowest loop: 4.20ms; fastest: 0.06ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 0.4ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 159, completed moves 159, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.3 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X211.8 Y150.0 " in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 4.50ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0 === CAN === Messages queued 171, send timeouts 0, received 512, lost 0, longest wait 1ms for reply type 6029, free buffers 48
Why is no console message being displayed?
Duet 3 standalone, everything on RC2
