help please
So Im in the process of converting a Chinese printer to duet. got most of my pieces finally so i can start assembling. nothing out of the packages until a few days ago. i get the pi connected, the the 6hc and the 3hc connected, go to hook up the paneldue 5i....white screen. no boot. i have tried to fix via the duet web interface, also with BOSSA on the pi and on WINDOWS. my duet web control version is 3.1.1
My problem so far is that i cannot get the pi or windows to recognize that the dev is plugged in (referring to the paneldue)
~printed solid referred me here to try and fix it
thanks
its a bit unclear, did you flash a new version with bossa on the paneldue?
Please try flashing PanelDue firmware 1.24 using USB and Bossa.
https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Firmware_update_via_USB
@Veti was able to flash after i posted this, thank you
@Phaedrux thank you, got it done. now trying to flash the 6hc. any tips? bossa cant connect
@bam
try different usb cables. some ppl had to try 18 different ones until they found one that worked.
