    Sample code for variable workaround
    Gcode meta commands
    • DaveAundefined
      DaveA
      Anyone have some sample code to show how to implement a workaround for not have conditional variables? I created a dummy tool and tried to use its offsets as holding places but I could not get it to work.
      • fcwiltundefined
        fcwilt
        If you would like to be able to see the current value of a text variable on the DWC you can use the name of a dummy fan.
        • DaveAundefined
          DaveA
          What I was hoping for is the ability to perform some simple arithmetic based on a set of readings. Maybe this just isn't possible yet.
            jay_s_uk @DaveA
            @DaveA I already do something similar. You can use the workplace coordinates to same information and then calculate from.
            I mainly use this when probing on my CNC. Examples can be found here https://forum.duet3d.com/topic/19698/rrf3-2-request-to-enable-g43-g44-tool-height-offset?_=1609278343985
