    Tuning issues on 3.2 RC2
    424
    • nick9one1undefined
      nick9one1
      I've been running 3.2 RC2 for a few days and its been absolutely fine.
      I thought I'd give the new tuning algorithm a try as I was never 100% convinced I'd previously tuned the hot end and bed particularly well.
      The tuning completes OK, but when printing I get
      at the start of layer 2 (part cooling fans are enabled).
      this is the result of M303 H1 S240
      M307 H1 R2.766 C215.7 D11.59 S1.00 V23.8				; Set PID for hotend values
      its an e3dV6.
      I stupidly forgot to save my previous pid values, but I'm sure the C value was around 300 (could be wrong).
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @nick9one1
        @nick9one1 said in Tuning issues on 3.2 RC2:
        M303 H1 S240
        with 3.2 you want to use M303 T0 S240 because it takes the fan into account.
        nick9one1undefined 1 Reply Last reply Reply Quote 0
          nick9one1
          Thanks I'll try that now.
          Is it still best to have the bed off and lowered away from the hot end when tuning?
          Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti @nick9one1
            @nick9one1
            with the sock on it i dont think it will make much difference
              nick9one1 @Veti
              @Veti
              So I ran it again
              M303 T0 S240
              This was the output, which I have updated in config.g. I can see it has an additional value for C
              M307 H1 R2.828 C212.5:154.2 D10.76 S1.00 V23.8
              but it still fails
                nick9one1
                Its definitely the tool fan thats causing issues.
                I just tried printing a hollow cube, and this time it didn't quite drop low enough to trigger the low temp failure, but when I manually turned off the fans, it failed on too high temp.
                The dip is where the part cooling fan was enabled at 100%
                the spike is where is turned it off
                • Vetiundefined
                  Veti
                  you are using the e3d sock?
                  what kind of fan shroud are you using?
                    nick9one1
                    Yes I am using the silicone sock.
                    • Vetiundefined
                      Veti
                      see
                      https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them
                      A very strong print cooling fan may cause the nozzle temperature to drop suddenly, either when it turns on at the end of the first layer, or subsequently if the print deflects the air on to the nozzle heater block. A drop of 10C is likely to cause extrusion difficulties as well as heater faults. Make sure that the print cooling fan is directed at the print, not at the heater block. Try insulating the heater block with a silicone sleeve or Kapton tape, and/or use a lower fan speed in your M226 settings.
                      you can adjust the settings for fault using M570
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M570_Configure_heater_fault_detection
                        dc42 administrators @nick9one1
                        No, it's better to have the bed close to the nozzle, so that the effect of the print cooling fan is similar to when printing.
                          nick9one1 @dc42
                          @dc42 thanks. I'll try that next.
                            nick9one1
                            A PID tune with the new algorithm right next to the bed has helped.
                            I now get a 9 Celsius drop when the fan comes on, and an 11c overshoot when its off.
                            Previously it was about 20c.
                            Is this acceptable? Still seems quite a lot?
                              That does seem a lot. Did you tune using T0 instead of H1 in the M303 command? Did the correct print cooling fan turn on when tuning reached the "Fan on" stage?
                              What M307 command did tuning generate?
                              • Vetiundefined
                                Veti
                                the dual part fan setup could be very strong.
                                put a small bowl of water underneath and see if the air flow is actually hitting underneath the nozzle
                                  nick9one1 @Veti
                                  Yes, I used M303 T0 S230, and yes the cooling fan did turn on. I could see the affect of it on the temp chart too.
                                  The result was;
                                  M307 H1 R2.777 C215.9:136.9 D10.87 S1.00 V23.8
                                  @Veti thanks, it looks like the air flow is hitting the water quite strongly. It could certainly be overpowered like you suggest. I've previously printed bridge and overhang tests like this with no problems.
                                  Is it possible to reduce the max output of the fans from config.g?
                                  e.g. If 80% provides enough cooling, I can still use 100% cooling in the slicer, but this translates to 80% when printing.
                                  • Vetiundefined
                                    Veti
                                    i have not used it but the x parameter might work
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
                                      The result was;
                                      Your hot end has quite a large dead time (10.87, whereas 5.5 is more typical) so unfortunately the feedforward will have a delayed effect. You could try reducing the value of the second C parameter, to see if you can replace the large undershoot by a smaller undershoot followed by a small overshoot (and vice versa when the fan is turned off).
