    Can-FD bus and ATX power
    • nrivieraundefined
      nriviera
      Maybe I'm terrible at googling but I can't seem to find a way to trigger an reconnect with a tool board. My setup uses ATX power control for Vin however when this is turned off the the toolboard loses power. When power is turned back on the toolboard doesn't reconnect and I need to reset the controller to do so. Is there a way to trigger the toolboard to reconnect?
      • oliofundefined
        oliof
        Try M999 B<address of toolboard>?
          Running M98 P"config.g" should be sufficient.
          nrivieraundefined 1 Reply Last reply Reply Quote 0
          • nrivieraundefined
            nriviera @dc42
            @dc42 thanks, works perfectly
