    Unsolved DUEX GPIO configuration
    • npretor
      npretor last edited by npretor
      I'm currently running a Duet and Duex5, and trying to control some external pumps and solenoids. I would like to trigger the solenoid using a gpio, but I have read the documentation and it's as clear as mud to me. I don't need high current, just a simple on and off for switching a MOSFET through gcode. I have no hotends and no fans, i'm using the Duet+Duex for controlling fluid dispensing on the E3D toolchanger.
      So far I have tested:
      1. Turning on and off existing fans I/Os with:
        M106 P7 S1.0. ; Turns on Fan7(according the PCB label)
        I have also set the fan voltage jumper to both 5V and 12V with no detectable voltage
      2. M307 P27 I-1. ;Disable fan 7? Not sure
        M42 P27 S1.0 ;Turn on what was Fan7 output to high?
      I also tried using the Duex GPIO pins which is my preferred method, but I honestly find the pin documentation sheet to be unreadable:
      https://duet3d.dozuki.com/Wiki/Duet_2_Pinout_table.
      What am I missing? Is there an example I can go off of that someone else had done for triggering something similar?
      Board: Duet WiFi 1.02 or later + DueX5
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
      Duet WiFi Server Version: 1.23
      • whosrdaddy
        whosrdaddy last edited by whosrdaddy
        @npretor said in DUEX GPIO configuration:
        • If you want to use M42, you must first unmap the fan port.
          This is done by command M106 P7 I-1, P7 refers to Fan #7 on the duex board.
        • Now you can use M42 P27 S255 to set the pin High or M42 P27 S0 to set the pin low.
          P27 is the logical pin number for Fan #7 as shown in the documentation
        • Be aware that the Duet board switches V- of the port, V+ is set to the Fan voltage jumper selection
        • npretor
          Ok thank you, appreciate the reply. I'll give it a shot!
