    duet3_sbciap_mb6hc.bin is missing ? can't run update (m997) ??
    Firmware installation
    404
    • jrocklandundefined
      jrockland
      Since I realized all those apt update - upgrade where useless since it didn't work since may, I tried doing it manually with m997 and I get "duet3_sbciap_mb6hc.bin is missing".
      I looked at all my other 6hc and it is the same everywhere.
      What is that file and where can I get that ?
        To update the SBC beyond the most recent stable release you need to add the unstable package server and then update. That's where the file will come from.
        See here for adding the unstable branch on the Pi:
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
        jrocklandundefined 1 Reply Last reply Reply Quote 0
          jrockland @Phaedrux
          @Phaedrux not looking into using unstable stuff, just want to keep the board updated.
          I gona have to try it anyway because since my 3hc got updated yesterday nothing work anymore and im stock with 3 massive paperweight.
            Well if you're not wanting to go to 3.2 RC2 but it's already flashed on the boards you can go back to 3.1.1.
            3.2 final release is near.
            @jrockland said in duet3_sbciap_mb6hc.bin is missing ? can't run update (m997) ??:
            sorry you're having a frustrating experience. It's a complex board, but with some patience and a plan anything is surmountable.
            jrocklandundefined 2 Replies Last reply Reply Quote 0
              jrockland @Phaedrux
              @Phaedrux Sorry I don't want to be mean, I'm kinda loosing my mind right now;
              I'm engineering parts for cars and machinery, I don't use linux or program stuff at all.
              I bought those boards because my machines are highly custom and the seller told me they where the easiest to use..
                jrockland @Phaedrux
                @Phaedrux don't get me wrong the user interface is awesome to work with when you are in my position..
                  jay_s_uk
                  can you post an output of M115 so we can see what firmware you're currently on?
                    jrockland @jay_s_uk
                    @jay_s_uk 3.1.1 19b2
                      Perhaps it would help to take a step back and come up with a plan on how to best integrate them with your machine.
                      The Duet3 by itself is exactly the same as a Duet 2 Ethernet. You don't need to use the Pi with it to get started. The SBC interface is definitely on the bleeding edge right now.
                      You can setup an SD card to function exactly like a Duet2 would use and be up and running. Adding a Pi later becomes a bit easier.
                      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
                        jrockland @Phaedrux
                        @Phaedrux well if I can get it to stabilize I just won't touch it anymore. I had to correct the issue with m999 not working with ext board asap because when you have over 60lbs of torque going wild parts start flying everywhere. it is the only reason I actually tried to force update.
                        I just got one of the board to accept the last rc2, Ill see if it work then I will just "freeze state" on my setup and stick with it..
                          Well whatever you decide to do to proceed we will be here to give a hand. Just remember we're all just people separated by time zones doing our best to help you.
                            jrockland @Phaedrux
                            @Phaedrux no worries, I knew it would take time to answer because on the time zone, and I'm actually surprise you even answer as it is the 1st of jan XD
                            I tough I was the only weirdo working right now..
                            thank so much for the help !
                              jrockland
                              It did work, and the m112 / m999 does work on all ext now. no more stepper motors flying anymore XD
                                Thanks, I'll mark this as solved then.
