6 pins Screen to Duet 2 wifi
Hi !
I want to put my 6 pins Screen to the Duet 2 wifi motherboard.
Where i can connect my Creality CR10S-Pro screen (DMT48270C043_06W) :
- +5 V
- RX4
- RX2
- TX2
- TX4
- GND
on the Duet 2 wifi motherboard ?
Here is the Datasheet for my screen but i don't understand china language !
Thanks
This post is deleted! -
@Eldianel said in 6 pins Screen to Duet 2 wifi:
are you sure that it is supported by the duet firmware?
most likely it is not.
@Veti it's a touch screen that could be run in "raw mode" (M575 S3) since the CR10S runs Marlin by default. I don't know the pinout though, but it should be easy to try either RX2/TX2 or RX4/TX4 for the serial comms.
Worth a try.
