    Upgrading to 3.2
    Beta Firmware
    368
    • mrenz999undefined
      mrenz999
      Trying to upgrade and keep getting this error
      Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3_SBCiap_MB6HC.bin
      Duet 3 and Duet 3 add on board with SBC
        What version are you trying to upgrade from? How are you trying to upgrade? sudo apt update/upgrade on the unstable channel?
        mrenz999undefined 1 Reply Last reply Reply Quote 0
        • mrenz999undefined
          mrenz999 @Phaedrux
          @Phaedrux I was on 3.1.1 and just uploaded the files. I see now that I need to do it through the SBC and ssh. I do not know how to go to the unstable.
            See here: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
            • mrenz999undefined
              mrenz999 @Phaedrux
              @Phaedrux Ok thank you. How do I upgrade my driver expansion board ?
                I feel like maybe you haven't read the getting started with Duet 3 guide.
                https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_expansion_board_firmware
                mrenz999undefined 2 Replies Last reply Reply Quote 0
                • mrenz999undefined
                  mrenz999 @Phaedrux
                  @Phaedrux I did now 🙂 thank you
                  • mrenz999undefined
                    mrenz999 @Phaedrux
                    @Phaedrux Ok all updated. Thank you for your help. I am getting no response from my extruder. Is there a new command or should it be working with this upgrade without anything additional added ?
                      Extruder won't turn unless tool is selected and up to temp, or you've allowed cold extrusion.
                      Otherwise need more details.
