    Please: need to update DWC
    Firmware installation
    778
    • deonholtundefined
      deonholt
      Thank you for your help. I am totally new to updating files on my board and don't know how to do this.
      My setup:
      Firmware Version: 2.05.1 (2020-02-09b1)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      I was advised to update my DWC to 2.0.7
      I downloaded the I downloaded the DuetWebControl zip file from here: https://github.com/Duet3D/DuetWebControl/releases/tag/2.0.7
      I just want to confirm:
      Do I upload the zip file with the web interface as on the picture or do I need to unzip first and then upload.
      It is probably better to make a backup of my printer files first. How do I do this?
      Any other pointer I need to know will be very welcome. Is there maybe a step-by-step installation via the web interface?
      Thanks.
      • Vetiundefined
        Veti
        you can upload the zip, it will be extracted during upload
        deonholtundefined 1 Reply Last reply Reply Quote 0
        • deonholtundefined
          deonholt @Veti
          @Veti thanks again. Do I need to make a backup first? If so, how do I do it? I appreciate your help.
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @deonholt
            @deonholt said in Please: need to update DWC:
            no for the update from 1 to 2 the old one is preserved.
            deonholtundefined 2 Replies Last reply Reply Quote 0
            • deonholtundefined
              deonholt @Veti
              @Veti great thanks. Just waiting for a print to finish and will then run the file.
              • deonholtundefined
                deonholt @Veti
                @Veti do I need to switch off and back on after uploading the file? I just uploaded the file and all were extracted 100%. The page then went completely empty ... I even refreshed the page ... no difference. I don't want to switch off and back on before you giving me the green light.
                Thanks.
                • Vetiundefined
                  Veti @deonholt
                  @deonholt
                  try a different browser.
                  if that works you need to clear the cache
                  deonholtundefined 2 Replies Last reply Reply Quote 1
                  • deonholtundefined
                    deonholt @Veti
                    @Veti great. Worked first shot. Thanks again.
                    • deonholtundefined
                      deonholt @Veti
                      @Veti I unfortunately need to change my reply to: "It worked once but not again". Anything I can try. I cannot even access it from my phone or tablet. Page remains empty. I don't get an error message ... only empty page.
                      The wifi seems ok. I could start a single layer square which is printing now. Page remains empty.
                      Any other advice will be most welcome. At the moment I am stuck with an empty page.
                      If needed, I can access the printer through a USB cable with my Laptop.
                      • Vetiundefined
                        Veti
                        what url are you accessing?
                        can you try in incognito mode?
                        • deonholtundefined
                          deonholt @Veti
                          @Veti I'm using the printer's IP address. I can successfully ping it and it is also listed as a connected device on router UI.
                          I tried with Edge, Firefox & Chrome, normal and private/incognito mode and in all instances just a blank page.
                          I have also switch off and back on the printer a couple of times.
                          • Vetiundefined
                            Veti
                            can you type in the url ip/reprap.htm
                            • deonholtundefined
                              deonholt @Veti
                              @Veti How did you know that? You're a genius. Thanks for sticking with me. I don't mind having it like this, but what did not happen or happen? I want to learn.
                              It doesn't look like it installed the file:
                              • Vetiundefined
                                Veti
                                no the reprap.htm will go back to version 1
                                can you try the release from here
                                https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                                deonholtundefined 1 Reply Last reply Reply Quote 1
                                • deonholtundefined
                                  deonholt @Veti
                                  @Veti
                                  Ok, thanks. I have just loaded the file again under ip/reprap.htm
                                  Nothing seemed different. I tried again to load the page but only with IP. And it refreshed to what seems to be the updated DWC.
                                  It looks a whole lot different and will have to learn the new layout ... but I like it.
                                  Thank you so much again for your help. Much appreciated.
                                  • deonholtundefined
                                    deonholt
                                    It says:
                                    Duet Web Control 2.0.7
                                    I'm so happy.
                                    • Vetiundefined
                                      Veti
                                      there will not be an update to version 2
                                      so you might consider going to rrf3, but that is a bit more as the config changes.
                                      • deonholtundefined
                                        deonholt @Veti
                                        @Veti
                                        Yes, I have learned that. I am not comfortable doing it myself at this stage. Will do it later some time.
                                        Thanks again. You have been a great help. The think I like for now the most is that I can change the baby-steps' increments.
