    E3D Titan Bowden Extruder setting up
    • AS-3D Druck
      AS-3D Druck last edited by
      Hey Guys,
      i'am the Owner of a Duet Wifi + e3D Titan (Standard Motor) and I am not quite sure if it gets enough "mA".
      Currently it's getting this: 800 mA
      Is this enough or sould it be adjusted?
      By the way it is in use as a Bowden Extruder. 😉
      Hope you can help me.
      Best regards
      AS-3D Druck / Andre
      • Dougal1957
        Dougal1957 last edited by
        that all depends on which motor you are using
        but try it and see
          E3D should tell you what current setting is appropriate for their motor. But if it's the new one with 42BYGHM208P4.5-15-X2 on the label, the datasheet I found here http://www.promoco-motors.com/products/StepperMotors/42BYGHM%20Series.pdf says it is rated at 1.2A. So if it is skipping steps, you could increase the current to 1000mA.
