    Diabase H Series - Tool Change T1,T2,T3,T4,T5 causing -Z
    270
    • katkillaundefined
      katkilla
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2-beta4.1 (2020-12-02)
      Duet WiFi Server Version: 1.23
      When executing any tool change command it changes the tool, then goes back to position, -z from where it was at then goes to the height it left off at. Where do I look for changing this behavior? Of course, this causes crashing issues if these commands are executed and im at Z=0. Thanks
        3.2 final is now available. May want to update from beta 4.1.
        Post your config and tool change files?
        • katkillaundefined
          katkilla
          Thanks! Let me update after my prints done and I will try the commands again and attach the config.
          • katkillaundefined
            katkilla
            I have updated it to the latest.
            Still same issue occurs.
            Goes up Z, switches tool head, goes down past its set position prior to the move and goes below it, and then back up to the saved coordinates.
            Example. Executing T4
            Starts at Z=0 goes up [0_1609874041494_Config 1.zip](Uploading 100%) to Z=25
            Changes Tool
            Goes to Z=-10 for example
            Then to the saved coordinates where it started at Z=0 before the tool change.
            Config Download - https://1drv.ms/u/s!AhdV-IvkdlDRgyTAt-q5PL6hMAGM?e=Okjwjx
            • katkillaundefined
              katkilla
              I just rebooted it and tried to print another item. It gets stuck at changing tool. What I updated was the Duet2CombinedFirmware.bin only so looks like it may have caused an issue.
                Upload the full combined zip file.
                katkillaundefined 1 Reply Last reply Reply Quote 0
                • katkillaundefined
                  katkilla @Phaedrux
                  @Phaedrux It says zip was not allowed to so I used a one drive link here https://1drv.ms/u/s!AhdV-IvkdlDRgyTAt-q5PL6hMAGM?e=Okjwjx
                  • wilrikerundefined
                    wilriker
                    @katkilla You can suppress head movements by using Tnn P0.
                    Manuel
                    My Tool Collection
                      Phaedrux Moderator @katkilla
                      @katkilla said in Diabase H Series - Tool Change T1,T2,T3,T4,T5 causing -Z:
                      Yes I got your config set, what I meant was for the firmware update. You said you uploaded just the bin file, but you should upload the full release zip file.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                      • katkillaundefined
                        katkilla @Phaedrux
                        @Phaedrux said in Diabase H Series - Tool Change T1,T2,T3,T4,T5 causing -Z:
                        Got it. I will wait till the company that sells the machine tests it, I have reverted it for now. It may require some additional changes after they perform the changes.
                        • katkillaundefined
                          katkilla
                          The vendor was able to get me sorted and had to rewrite the tool gcode files all set! Thanks
