    Board not connect post firm upgrade
    894
    • Cata
      Cata last edited by
      My duet wifi not respond. I was on firm 1.17 (never update the board, its buyed by this page), i try to update to 1.18 and web server dont respond more. Try fallback procedure #1/2/3 in that order and now dont see in com port connected with usb. Can i do something?
      Order ID #888 Date 07/03/2017
        If you press the Erase button for one second and then press the Reset button, does the Bossa Port appear in the COM port listing?
        • Cata
          Cata last edited by
          Yes,
          • Cata
            Cata last edited by
            I try a few times more with bossa and cant connect with pronterface or repetier after flash. Board continues resetting past 1 min, windows blip the sound of the com connecting and disconnecting.
              Check the size of the firmware file you downloaded and are flashing to the Duet. It should be around 300kbytes.
              After a successful firmware update, check how the Duet shows up in Device Manager. You may need to install the new device driver from https://github.com/dc42/RepRapFirmware/tree/dev/Driver before you can access it.
              • Cata
                Cata last edited by
                I will try in a few hours. I use 3 firms, 2 1.18 downloaded well with the same size and the last firm I have, 1.17.
                • Cata
                  Cata last edited by
                  @dc42:
                  Yes, i see ok
                  But its rebooting every 20 seconds.
                  • Cata
                    Cata last edited by
                    Update: without the sdcard dont reboot, its stable. But when i send m552 s1 the reboot its back.
                    • Cata
                      Cata last edited by
                      I try another sd card and duet its rebooting when the sd card is present in the boot, if i put before no reboots but can use the comand M997 S1 or M552 S1 (this last makes a reboot)
                      • Cata
                        Cata last edited by
                        Update #759
                        I finally delete all the sd and only leave a /sys folder with the firmware parts, the duet dont reboot with this sd inserted end i can do this
                        Connecting…
                        Printer is now online.
                        M997 S1
                        SENDING:M997 S1
                        Trying to connect at 460800 baud:
                        success
                        Erasing 290848 bytes...
                        Uploading file...
                        5% complete
                        10% complete
                        15% complete
                        20% complete
                        25% complete
                        30% complete
                        35% complete
                        40% complete
                        45% complete
                        50% complete
                        55% complete
                        60% complete
                        65% complete
                        70% complete
                        75% complete
                        80% complete
                        85% complete
                        90% complete
                        95% complete
                        Upload successful
                        M997 S2
                        SENDING:M997 S2
                        success
                        Erasing 3125248 bytes...
                        Uploading file...
                        5% complete
                        10% complete
                        15% complete
                        20% complete
                        25% complete
                        30% complete
                        35% complete
                        40% complete
                        45% complete
                        50% complete
                        55% complete
                        60% complete
                        65% complete
                        70% complete
                        75% complete
                        80% complete
                        85% complete
                        90% complete
                        95% complete
                        Upload successful
                        m552 s1
                        SENDING:M552 S1
                        WiFi server starting up
                        DuetWiFiServer version 1.03 (ch fork)
                        Flash size 4194304, free RAM 32840 bytes, WiFi Vcc 3.03V, host name: duetwifi1, reset reason: Turned on by main processor
                        WiFi server connected to access point CAT1, IP=192.168.1.10, signal strength=-52dBm
                        My god, why always have problems whit the **** wifi module?
                          Looks like you've made progress! Edit your config.g file, commenting out the M552 S1 line. Then it should boot up OK, with WiFi disabled. Then install new WiFi firmware by copying the DuetWiFiServer file to the SD card, renaming it to exactly DuetWiFiServer.bin, and use M997 S1 to install it. If you've installed main firmware 1.18.2 then the correct WiFi firmware version to use is 1.03-ch.
                          EDIT: you got there first.
                          • Cata
                            Cata last edited by
                            No, with the config.g empy or with any caracter dont boot ok, always reboot. First thing i do was comment the m552.
                            Now i will put back the duet in the printer, prints like none has passed.
