Duet Wifi missing X-movement commands
Hey.
Ive installed a Duet Wifi(2), on my Creality CR-5 Pro.
However it seems that it misses X-movement commands randomly.Ive tried several different models and different slicers, all with the same result.
The attached image is showing a hollow square of 100x100mm (and a skirt).What could be causing this?
RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
those are layer shifts.
they can be causes by not enough current (around 75% of rated stepper current)
friction in the axis.
to high acceleration.
Increased current for the motors and that solved it! Thanks
