    Duex2 Drive5(E2) and Drive5(E3) not working
    • kvlunagariya
      kvlunagariya last edited by
      I am using following config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 08 2021 13:51:22 GMT+0530 (India Standard Time)
      M550 P"My Printer" ; set printer name
      M552 P192.168.1.22 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.1.254 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S1 ; enable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P5 S1 ; physical drive 5 goes forwards
      M569 P6 S1 ; physical drive 6 goes forwards
      M584 X0 Y1 Z2 E3:4:5:6 ; set drive mapping
      M350 X256 Y256 Z256 E256:256:256:256 I1 ; configure microstepping without interpolation
      M92 X20157.48 Y20157.48 Z20157.48 E420.00:420.00:142.22:10240 ; set steps per mm
      M566 X50.00 Y50.00 Z50.00 E120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X200.00 Y200.00 Z200.00 E1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X50.00 Y50.00 Z20.00 E192.00:192.00:192.00:192.00 ; set accelerations (mm/s^2)
      M906 X300 Y300 Z300 E800:800:1800:1800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X230 Y210 Z200 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless endstop for low end on X
      M574 Y1 S3 ; configure sensorless endstop for low end on Y
      M574 Z1 S3 ; configure sensorless endstop for low end on Z
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M140 H-1 ; disable heated bed (overrides default heater mapping)
      M308 S0 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 0 as thermocouple via CS pin spi.cs1
      M950 H0 C"duex.e2heat" Q100 T0 ; create nozzle heater output on duex.e2heat and map it to sensor 0
      M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H0 S280 ; set temperature limit for heater 0 to 280C
      M308 S1 P"spi.cs2" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs2
      M950 H1 C"duex.e3heat" Q100 T1 ; create nozzle heater output on duex.e3heat and map it to sensor 1
      M308 S2 P"spi.cs3" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs3
      M950 H2 C"duex.e4heat" Q100 T2 ; create nozzle heater output on duex.e4heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M308 S3 P"spi.cs4" Y"thermocouple-max31856" ; configure sensor 3 as thermocouple via CS pin spi.cs4
      M950 H3 C"duex.e5heat" Q100 T3 ; create nozzle heater output on duex.e5heat and map it to sensor 3
      M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H3 S280
      M950 P1 C"fan1"
      M106 P1 S0 H-1
      M950 P2 C"fan2"
      M106 P2 S0 H-1
      M950 P3 C"e0heat"
      M106 P3 S0 H-1
      M950 P4 C"e1heat"
      M106 P4 S0 H-1
      M950 P5 C"bedheat"
      M106 P5 S0 H-1
      M563 P1 S"Heater 1" H0
      G10 P1 R240 S240
      M563 P2 S"Heater 2" H1
      G10 P2 R240 S240
      M563 P3 S"Heater 3" H2
      G10 P3 R240 S240
      M563 P4 S"Heater 4" H3
      G10 P4 R240 S240
      M563 P0 F0 ; define tool 0
      Problem is i am not able to drive motor 5 and 6 with G0 code.
      Please suggest any solution to this.
        Can you please provide the results of M122 and M98 P"config.g"
        kvlunagariya 1 Reply Last reply Reply Quote 0
          Phaedrux Moderator @kvlunagariya last edited by
          @kvlunagariya said in Duex2 Drive5(E2) and Drive5(E3) not working:
          You should use x16 microstepping with interpolation enabled. x256 on all drives will likely result in issues.
          • kvlunagariya
            kvlunagariya @Phaedrux last edited by
            @Phaedrux
            M122
            === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later + DueX2<LF>Board ID: 08DGM-917NK-F2MS4-7J9F6-3SN6L-9GUNG<LF>Used output buffers: 1 of 24 (13 max)<LF>=== RTOS ===<LF>Static ram: 27980<LF>Dynamic ram: 94988 of which 20 recycled<LF>Exception stack ram used: 304<LF>Never used ram: 7780<LF>Tasks: NETWORK(ready,368) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1840) IDLE(ready,80)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:21 ago, cause: power up<LF>Last software reset at 2021-01-08 17:46, reason: User, spinning module GCodes, available RAM 7772 bytes (slot 3)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN<LF>Error status: 0<LF>MCU temperature: min 28.3, current 29.3, max 29.4<LF>Supply voltage: min 11.6, current 11.7, max 11.7, under voltage events: 0, over voltage events: 0, power good: yes<LF>Driver 0: standstill, SG min/max not available<LF>Driver 1: standstill, SG min/max not available[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
            M98
            HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is enabled on port 23<LF>Error: Fan number 1 not found<LF>Error: Fan number 2 not found<LF>Error: Fan number 3 not found<LF>Error: Fan number 4 not found<LF>Error: Fan number 5 not found<LF>Tool 0 offsets: X0.00 Y0.00 Z0.00<LF>ok<LF>
              Can you please change your end of line settings in YAT so that the formatting is easier to read and the entire output can be captured?
