    PanelDueFirmware 3.2.7 released
    PanelDue
    1
    • wilriker
      wilriker last edited by wilriker
      I am pleased to announce release 3.2.7 of PanelDueFirmware. This release addresses two major limitations: tools with multiple heaters are now supported and also additional bed/chamber heaters will fill up unused screen estate. For detailed update information see below.
      Version 3.2.7
      Upgrade Notes:
      • This release is compatible with RepRapFirmware 3.2 or later. It will partially work with RepRapFirmware 3.1.1 but not with any older version.
      Limitations
      • Due to the lack of RAM this build will not run on version 1 or early version 2 PanelDue boards that use the ATSAM3S2B chip.
        • Version 1.0, 1.1 and earlier v2 PanelDue: ATSAM3S2B processor (64MHz, 32kb RAM, 128kB flash) - these are the ones that the new firmware probably won't run on.
        • Version 2 PanelDue manufactured from August 2016: ATSAM3S4B processor (64MHz, 48kb RAM, 256kb flash). Will run the new firmware, but not as fast as version 3 will.
        • Version 3 PanelDue, including all 5i and 7i: ATSAM4S4B processor, 120MHz, 64kB RAM, 256kb flash. Will run the new firmware.
      Changed:
      • Fill left screen estate with addtional bed and chamber heaters
      • Support tools with multiple heaters
      • Reduced flickering while initialization
      • Bring minimum and maximum axes count in line with RRF
      • Respect spindle minimum RPM
      Bug fixes:
      • First bed/chamber/tool/axis could not be removed
      • On 4.3" macro shortcut buttons would not show up even if there was enough space left
      • If more tools or beds that can be displayed were defined this could lead to illegal memory access
      • Fix possible memory leaks in object model representation
      Known Issues:
      • A heater in fault state will show two-color button in light theme (magenta and green)
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2.7
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      • wilriker
        I have just release PanelDueFirmware 3.2.8. Please continue in this thread.
        Manuel
        My Tool Collection
