    PanelDueFirmware 3.2.8 released
    PanelDue
    549
    • wilrikerundefined
      wilriker
      I am pleased to announce release 3.2.8 of PanelDueFirmware. This is mainly a bugfix release to address bugs introduced in 3.2.6 and 3.2.7. For details see release notes below.
      Version 3.2.8
      Upgrade Notes:
      • This release is compatible with RepRapFirmware 3.2 or later.
      Limitations
      • Due to the lack of RAM this build will not run on version 1 or early version 2 PanelDue boards that use the ATSAM3S2B chip.
        • Version 1.0, 1.1 and earlier v2 PanelDue: ATSAM3S2B processor (64MHz, 32kb RAM, 128kB flash) - these are the ones that the new firmware probably won't run on.
        • Version 2 PanelDue manufactured from August 2016: ATSAM3S4B processor (64MHz, 48kb RAM, 256kb flash). Will run the new firmware, but not as fast as version 3 will.
        • Version 3 PanelDue, including all 5i and 7i: ATSAM4S4B processor, 120MHz, 64kB RAM, 256kb flash. Will run the new firmware.
      Changed:
      • Added Ukrainian translation (disabled for now) - thanks vitaliy172
      • Removed unused fonts
      • Move heater status into bed and chamber only to save some RAM
      • Support multiplexed heaters
      • Add color gradient to buttons in Dark 1 theme
      Bug fixes:
      • Fan used fans[].actualValue instead of fans[].requestedValue
      • Color gradient for heater-fault was broken on Light theme
      • Additional bed and heater buttons alwaysed controlled the first bed or chamber respectively
      • Extrusion factor could be shown for an element without an extruder
      • Active/standby controls for tools with multiple heaters always set all heaters of this tool
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2.8
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      BoAundefined Stephen6309undefined 2 Replies Last reply Reply Quote 1
      • BoAundefined
        BoA @wilriker
        @wilriker There is something strange going on in this firmware...
        https://www.youtube.com/watch?v=_dw5heELJEw
        • wilrikerundefined
          wilriker @BoA
          @BoA please provide the output of
          M409 K"heat" F"d99vn"
          M409 K"tools" F"d99vn"
          Manuel
          My Tool Collection
          • BoAundefined
            BoA
            Commands executed during print.
            console.txt
            Seems there is some relation with bed heater and tool1:
            https://www.youtube.com/watch?v=E9w-VdB8ghc
            T1 state "blinks" with the same state as heatbed.
            On video it is on stby, but making it active makes T1 blinking in red also.
            And after pressing Emergency Stop:
            • Stephen6309undefined
              Stephen6309 @wilriker
              @wilriker Sent M997 S4, and I get: Error: M997: Network-related commands are not supported when using an attached Single Board Computer
              Duet 3 Mini with 3.2 and a Pi4.
              • oozeBotundefined
                oozeBot
                I’ve also seen my macros blank out like that this am after upgrading to 3.2.8 and the rapid blinking of temps like in your video.
                • flopo76undefined
                  flopo76
                  Thanks,when Italian language?
                  • MartinNYHCundefined
                    MartinNYHC
                    Same here...
                    If you touch the field once it is shown properly again.
                    • wilrikerundefined
                      wilriker
                      Thanks all for reporting and confirming. I will have a look at these today.
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker @flopo76
                        @flopo76 said in PanelDueFirmware 3.2.8 released:
                        I don't speak Italian so unless someone is willing to translate the strings at https://github.com/Duet3D/PanelDueFirmware/blob/master/src/Strings.hpp#L123 there is not much I can do unfortunately.
                        Manuel
                        My Tool Collection
                        • wilrikerundefined
                          wilriker
                          And I released PanelDueFirmware 3.2.9 that hopefully fixes all the mentioned issues. It turned out that the bug with broken macro buttons was in fact a side-effect of the status-bug and I could no longer reproduce it once I fixed the that.
                          Please continue in the other thread and apologies for the numerous releases.
                          Manuel
                          My Tool Collection
