    The chamber heater does not fit
    My Duet controlled machine
    1
    • konte1978undefined
      konte1978
      Hi guys, I can't start the chamber heater.
      the ssr is connected to output 3 of the duex 5. I am attaching configuration files
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Jul 17 2020 20:24:58 GMT+0200 (CEST)
      M550 P" CUBE PRO TRIO" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards HO MODIFICATO S1 CON S0
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P9 S1 ; physical drive 9 goes forwards
      M584 X0 Y1 Z2 E3:4:9 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X87.35 Y87.43 Z1076.77 E80.59:78.85:79.87 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z1200.00 E600.00:600.00:600.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z800 E1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent (ho modficato la corrente dei motori dell'estrusore da 800 a 1200)
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z0 S1 ; Imposta valore minimo deli assi HO SOSTITUITO IL VALORE S0 CON S1
      M208 X290 Y295 Z205 S0 ; imposta il valore massimo degli assi HO MODIFICATO IL VALORE S1 CON S0 Y DA 295.3 A 295
      M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop HO MODIFICATO IL VALORE Y1 A Y2
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M950 S0 C"duex.pwm5" ; creare il servo pin 0 per BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 A10 R0.75 S0.02 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-11 Y49.50 Z2.85 ; impostare il valore del trigger della sonda Z, l'offset e l'altezza del trigger 2.50 lasco 2.85 serrato
      M557 X11:276.9 Y0:263 S20 ; define mesh grid misure minime e massime di dove andrà a sondare il bltouch
      ;Piatto riscaldato
      ;M570 H0 P90 T20 ; sto cercando di far aspettare fino che il piatto si riscaldi prima che mi dia errore
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp ho modificato il valore dalla B4138 CON 3950
      M143 H0 S110 ; set temperature limit for heater 0 to 120C
      ;Estrusore numero 1
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S290; set temperature limit for heater 0 to 120C
      ;Estrusore numero 2
      M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S270
      ;Estrusore numero 3
      M308 S3 P"spi.cs3" Y"rtd-max31865" ; M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4725 ; configure sensor 3 as thermistor on pin duex.e2temp
      M950 H3 C"duex.e2heat" T3 ; create nozzle heater output on duex.e2heat and map it to sensor 3
      M143 H3 S270 ; set temperature limit for heater 0 to 120C
      M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      ; Riscaldatore della camera
      M141 H4 ; il riscaldatore 4 è il riscaldatore della camera
      M308 S4 P"duex.e3temp" Y"thermistor" T100000 B5500 C7.06Ee-8 ; configure sensor 4 as thermistor on pin duex.e2temp
      M950 H4 C"duex.e3heat" T4 ; configura l'uscita per il riscaldamento della camera sull pin e della scheda duex MODIFICATO 3 CON 4
      M143 H4 S70 ; set temperature limit for heater 0 to 120C
      M301 H4 B1 ; utilizzare il controllo bang-bang per il riscaldatore della camera OK
      M106 P0 C"ESTRUSORI" S0 H3:2:1 T120 ; set fan 0 name and value. Thermostatic control is turned on
      M106 P1 C"NOZZLE" S0 H1:2:3 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M106 P2 C"LUCI LED" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
      M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
      M106 P3 C"VENTOLA 6" S0 H-1 ; set fan 3 name and value. Thermostatic control is turned off
      M950 F4 C"duex.fan7" Q500 ; create fan 4 on pin duex.fan7 and set its frequency
      M106 P4 C"VENTOLA 7" S0 H-1 ; set fan 4 name and value. Thermostatic control is turned off
      ; Tools motori estrusore
      M563 P0 S"estrusore 1" D0 H1 F0:1 ; define tool 0
      M563 P1 S"estrusore 2" D1 H2 F0:1 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 S"estrusore 3" D2 H3 F0:1 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      ; Sensori di folamento degli estrusori se imposto l'ultima S0 disabilita il confronto tra filamento aspetatto e quello realmente estruso,S1 abilita il controllo
      M591 D0 P5 C"e0stop" R5:190 E3.0 S0 ; ho configurato il filamento del primo estrusore sull'uscita e0stop valori sensibilità filamneto originale R40:120
      M591 D1 P5 C"connlcd.encb" R5:190 E3.0 S0 ; ho configurato il filamento del secondo estrusore sull'uscita stop10(ECN_B) valori sensibilità filamneto originale R40:120
      M591 D2 P5 C"e1stop" R5:190 E3.0 S1 ; ho configurato il filamento del terzo estrusore sull'uscita e1stop valori sensibilità filamneto originale R40:120
      M575 P1 S1 B57600 ;per abilitare lcd paneldue
      M501 ;Legge i parametri dalla eprom
        konte1978
        problem solved, in RRF3 if the heater is different from H1 this order must be respected.
        M950
        M141
        M143
