    DWC 3.2, gcode editor issue
    Duet Web Control
    • garyd9
      garyd9 last edited by
      Conditional gcode (at least with DSF) is very sensitive to the difference between spaces and tabs for conditional blocks of code. For that reason, if the DWC gcode editor is going to autoindent on new lines, it needs to either differentiate between space and tab characters, or it needs to automatically replace 'tab' characters with spaces.
      For example, assume I type the following in the gcode editor. All characters are as typed, with special keys using angled braces (ie: <backspace>, <tab>, <return>):
      while true<return>
      <tab>echo "test 1"<return>
      echo "test 2"<return>
      What happens above is that after the line that echo's "test 1", the gcode editor is helpfully auto-indenting the next line. However, it's NOT using a tab character to indent, and instead inserting 4 spaces. The resulting gcode LOOKS okay and with proper indenting, but it's NOT because the echo of "test 1" is preceded by a single tab character and the echo of "test 2" is preceded by 4 space characters.
      This results in some very odd things happening when running conditional gcode that appears to be perfect (and debugging it isn't fun.)
      Suggestion: Either the gcode editor should copy the characters used to indent the previous line, OR it should re-write TAB characters to sequences of spaces (which is probably easier than re-writing sequences of spaces to tabs.) Or, perhaps it should use it's syntax highlighting to change the background color of TAB characters to make it obvious that something is different...
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
      • T3P3Tony
        hi @garyd9 thanks for pointing this out. I hope its a relatively easy firx for @chrishamm
        Personally it think replacing tabs with 4 (or use configurable) number of spaces is probably best.
        I think this does not come up as much as it might because its not normal to type a <tab> character in a browser, at least on windows, as tab moves the focus. I know DWC's code editor does allow for tab capture and insertion, but people may be conditioned not to tab in a browser!
        www.duet3d.com
        • jay_s_uk
          jay_s_uk last edited by
          I use tabs a lot in the gcode editor. Especially for lining up the comments.
          I think it may get used more than expected, especially by coders used to using tabs for indents.
          • T3P3Tony
            Fair enough! anyway I have logged it:
            https://github.com/Duet3D/DuetWebControl/issues/321
            T3P3 created this issue in Duet3D/DuetWebControl
            closed Whitespace Consistency in DWC gcode editor #321
            www.duet3d.com
            • DaveA
              DaveA last edited by
              Would there be any possibility to have the DWC use an external editor such as NotePad++? In the Arduino IDE you can elect to use any editor you like.
              • chrishamm
                chrishamm administrators last edited by
                Thanks for pointing this out. I've got a change for DSF ready so it will treat tabs just like RRF (i.e. to add up to 4 spaces to the current indentation level). I'll try to change the new editor to auto-insert tabs if the last line contains tabs, too.
                Duet software engineer
