    Temperature sensors options
    • Anto0131undefined
      Anto0131
      Hello all,
      I'm requesting your help on my problem concerning the limitation of temperature sensor inputs on the Duet Ethernet.
      I have 2 independent extruder with their own hotend sensor. I also have a heated bed and an ambient enclosure heater.
      My duet ethernet is linked with a Duet Expansion Breakout Board required for 4 external drives.
      That configuration does give me the ability to monitor the temperature of the air ambient. I could use a SSR and the breakout board pwm to control the ambient heater but I'm short one temperature sensor.
      Can someone help me on my option here? Is there a temperature sensor I could use with my RPY and feed to the duet (standalone one wire DS18B20) or something similar?
      Thank you everyone.
      A.
        jay_s_uk @Anto0131
        @Anto0131 you could by a temperature sensor daughter board for a PT100 or K type thermocouple. You can add up to 2 of either of these giving you 4 extra temperature sensors
        • Anto0131undefined
          Anto0131
          Thanks a lot Jay!
