    RRF 3 with piezo z probe not working
    Firmware installation
    321
    • Citystarsundefined
      Citystars
      i have the new firmware on my duet 2 wifi v3.2
      Changed all the settings for the new firmware but i can't get it to work with the piezo z probe.
      Im using the precision piezo on the extruder, it worked on the other firmware.
      When i touch the extruder i see in the web the value change from 0 to 1000.
      But the motor doesn't stop.
      Thats what i found on the wiki:
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M558
      Here is my config.g
      M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
      M574 Z0 P"nil" 					     ; no Z endstop switch, free up Z endstop input
      M558 P5 C"!zstop" H2 F120 T3000  ; Z probe connected to Z endstop input
      G31 P600 X0 Y0 Z-0.1
      M557 X25:280 Y25:270 S13       ; Define mesh grid
      Thank you
        Phaedrux Moderator @Citystars
        @Citystars said in RRF 3 with piezo z probe not working:
        What was the other firmware?
        M574 Z0 P"nil"
        You can delete that line entirely.
        Are you using G30 to test?
        What version of precision piezo is it? It's sometimes recommended to use M558 P8 instead.
        Citystarsundefined 1 Reply Last reply Reply Quote 0
          Citystars @Phaedrux
          @Phaedrux
          Thank you for the fast reply
          The other version is was using was V2.02
          In the other version i was using
          M574  S1                          ; Set active high endstops
          M574 X1 Y1 Z1 S0
          M558 P7 I1 H2 R1 F100 T1000       ; Set Z probe type to switch and the dive height + speeds
          G31 P600 X0 Y0 Z-0.05          ; Set Z probe trigger value, offset and trigger height
          Im using the Precision Piezo Orion kit.
          Not using the G30 to test.
          Just making sure the bed is low enough and homing Z axis and pressing on the extruder to see if it stops.
          Thank you
            Ok, but how is it homing the Z axis?
            Post your homing files.
              Citystars @Phaedrux
              @Phaedrux
              Im just using the home Z axis button on the web.
              They are standaard configurations from the RepRapFirmware Configuration Tool.
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 11 2021 21:00:16 GMT+0100 (Midden-Europese standaardtijd)
              G1 H2 Z5 F6000          ; lift Z relative to current position
              G1 H1 X-305 Y-293 F1800 ; move quickly to X or Y endstop and stop there (first pass)
              G1 H1 X-305             ; home X axis
              G1 H1 Y-293             ; home Y axis
              G1 X5 Y5 F6000          ; go back a few mm
              G1 H1 X-305 F360        ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y-293             ; then move slowly to Y axis endstop
              G1 H1 Z-385 F360        ; move Z down stopping at the endstop
              G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
              ;G91                    ; relative positioning
              ;G1 Z5 F100             ; lift Z relative to current position
              ;G90                    ; absolute positioning
              ; homex.g
              ; called to home the X axis
              G1 H1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000       ; go back a few mm
              G1 H2 Z-5 F6000   ; lower Z again
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-293 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000       ; go back a few mm
              G1 H1 Y-293 F360  ; move slowly to Y axis endstop once more (second pass)
              ; homez.g
              ; called to home the Z axis
              G1 H1 Z-385 F1800 ; move Z down until the endstop is triggered
                G1 H1 Z-385 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                Ok, there's your problem. the part that homes the Z axis is using endstop homing commands rather than the probe.
                In homeall change this
                To this
                G1 X150 Y150 F6000 ; move probe to center of bed
                G30 ; probe for Z0
                Same for homez.
                  Citystars
                  @Phaedrux said in RRF 3 with piezo z probe not working:
                  G1 X150 Y150 F6000 ; move probe to center of bed G30 ; probe for Z0
                  Thank you the homing works now.
                  I still have one question.
                  Would this homing homingall.g be allright?
                  G91 				; use relative positioning
                  G1 H2 X0.5 Y-0.5 F10000	; energise motors to ensure they are not stalled
                  M400 				; make sure everything has stopped before we change the motor currents
                  M913 X20 Y20 		; drop motor currents to 25%
                  G1 H2 Z3 F5000		; lift Z 3mm
                  G1 H1 X-400 F3000 	; move left 400mm, stopping at the endstop
                  G1 H1 Y-400 F3000   ; move left 400mm, stopping at the endstop
                  G92 X0 Y0           ; set position x and y
                  G1 X3 F300          ; move away from the endstops
                  G1 Y3 F300          ; move away from the endstops
                  G1 H1 X-10          ; fine home X
                  G1 H1 Y-10          ; fine home X
                  G90 				; back to absolute positioning
                  G1 X25 Y25 F300     ; go to position
                  M400 				; make sure everything has stopped before we reset the motor currents
                  M913 X100 Y100 		; motor currents back to 100%
                  G30 				; probe for Z0
                  G1 X0 Y0 F1000		; Park
                  G1 Z0 F200          ; Park
                  Thank you
                    G91 ; use relative positioning G1 X150 Y150 F6000 ; move probe to center of bed
                    I'd probably make that an absolute move and adjust it so that the probe is actually centered.
