    Probe output wiring (NPN Inductive)
    • AS-3D Druck
      AS-3D Druck last edited by
      Hello guys i got a realy quick Question "i hope".
      I got my Probe NPN running with 24V and use a Relai to switch the 3.3V from the Board to the Pin that need that 3.3V as Signal.
      Now i got the Wiring Diagramm for the Duet Wifi open and don't know the Pin for the Signal.
      Is it: Z_PROBE_MOD or Z_PROBE_IN?
      I tryed already Z_PROBE_IN but i don't wanna destroy the Board so i hope you can help me to prevent me from that. 🙂
      By the way this is the Code i entered (Mode 5):
      M558 P5 X0 Y0 Z1 F500 T5000 H3
      Best regards
      AS-3D Druck / Andre
        You could connect the relay contacts between Z_PROBE_IN and ground and use probe type 5, but it's probably better to connect them to the 2 outer pins of the E0 endstop connector and use probe type 4. You will need to include parameter I1 in your M558 command to invert the signal polarity.
        • AS-3D Druck
          Ok, but why is the E0 better than the Probe Pins?
          I mean there are made for this right?
          (Just to undestand it) 😉
          Best regards
          AS-3D Druck / Andre
            E0 has a lower value pullup resistor.
