SOLVED 3.2 SBC cancel print not working w/ missing/blank cancel.g
  • Hi there. I have a problem.
    If I have to cancel a print and start this or another, the extruder no longer feeds filament.
    Only when I reboot the Raspberry Pi 4 does the pressure go back to normal.
    Use a Duet3 6hc with Raspberry Pi 4.
    It can be reproduced at any time.
  • Can you post your config.g file along with the pause.g and cancel.g if you have one.
    Can you also confirm the firmware version you are currently running?
  • ; Configuration file for Duet 3 (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 26 2020 16:14:58 GMT+0200 (MitteleuropƤische Sommerzeit)
    M550 P"Duet3"                                      ; set printer name
    M912 P0 S-5                                        ; sstzt CPU Temp korrektur
    M669 K1                                            ;switch to core X/Y mode
    M569 P0.0 S0 D3 V50 H50                                 ; X physical drive 0.0 goes forwards
    M569 P0.1 S0 D3 V50 H50                                 ; Y physical drive 0.1 goes forwards
    M569 P0.2 S1 D3 V50 H50                                 ; Z1 physical drive 0.2 goes forwards
    M569 P0.3 S1 D3 V50 H50                                 ; Z2 physical drive 0.3 goes forwards
    M569 P0.4 S1 D3 V50 H50                                 ; Z3 physical drive 0.4 goes forwards
    M569 P0.5 S0 D3                                    ; E physical drive 0.5 goes backwards
    ; Stealthchop
    M915 P0.0 T50
    M915 P0.1 T50
    M915 P0.2 T50
    M915 P0.3 T50
    M915 P0.4 T50
    M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5                   ; set drive mapping
    M92 X80.00 Y80.00 Z800.00 E462.10                  ; set steps per mm
    M566 X850.00 Y850.00 Z200.00 E800.00               ; set maximum instantaneous speed changes (mm/min)
    M203 X8000.00 Y8000.00 Z500.00 E5000.00            ; set maximum speeds (mm/min)
    M201 X900.00 Y900.00 Z100.00 E800.00               ; set accelerations (mm/s^2)
    M906 X1075 Y1075 Z1000 E950 I50                    ; set motor currents (mA) and motor idle factor in per cent
    M84 S120                                           ; Set idle timeout
    M208 X300 Y300 Z295 S0                             ; set axis maxima
    M574 X1 S1 P"io2.in"                               ; configure active-high endstop for low end on X via pin io2.in
    M574 Y1 S1 P"io1.in"                               ; configure active-high endstop for low end on Y via pin io1.in
    M574 Z1 S2
    M950 S0 C"io7.out"                                                    ; create servo pin 0 for BLTouch
    M558 P9 C"^io7.in" H5 F300 T3000                                      ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X38.884 Y2.578 Z0.00                                         ; set Z probe trigger value, offset and trigger height
    M557 X40:260 Y40:260 S40                                              ; define mesh grid
    M671 X-33.985:142.224:318.433 Y-16.206:312.004:-16.206 S50            ; Z lift Point Position
    M308 S0 A"Bett" P"temp0" Y"thermistor" T100000 B4100                  ; configure sensor 0 as thermistor on pin temp0
    M950 H0 C"out0" T0                                                    ; create bed heater output on out0 and map it to sensor 0
    M307 H0 A176.1 C1192.2 D31.2 S1.0 V24.3 B0                            ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                                               ; qmap heated bed to heater 0
    M143 H0 S140                                                          ; set temperature limit for heater 0 to 120C
    M308 S1 A"Vulcano" P"temp1" Y"thermistor" T100000 B4610 C7.060000e-8  ; configure sensor 1 as thermistor on pin temp1
    M950 H1 C"out2" T1                                                    ; create nozzle heater output on out1 and map it to sensor 1
    M307 H1 A367.3 C225.2 D2.8 S0.5 V24.6 B0                              ; disable bang-bang mode for heater  and set PWM limit
    M308 S2 A"Elektro" P"temp3" Y"thermistor" T100000 B4100               ; configure sensor 1 as thermistor on pin temp1
    M308 S3 Y"drivers" A"Stepper"                                         ; configure sensor 3 as temperature warning and overheat flags on the TMC2660 on Duet
    M308 S4 Y"mcu-temp" A"MCU"                                            ; configure sensor 4 as thermistor on pin e1temp
    M950 F1 C"out7" Q500                               ; create fan 1 on pin out7 and set its frequency
    M106 P1 C"Hotend" S1 H1 T50                        ; set fan 1 name and value. Thermostatic control is turned on
    M950 F0 C"out4" Q2500                              ; create fan 0 on pin out4 and set its frequency
    M106 P0 C"Bauteil1" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
    M950 F2 C"out9" Q500                               ; create Light on pin out9 and set its frequency
    M106 P2 C"Licht" S0 H-1
    M950 F3 C"out8" Q500                               ; create fan 3 on pin out8 and set its frequency
    M106 P3 H3:4 T38                                   ; set fan 3 value
    M563 P0 S"Vulcano" D0 H1 F0                        ; define tool 0
    M564 S1 H0
    T0
    ;M575 P1 S1 B57600                                 ; enable PanelDue
    M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    M501                                              ; load saved parameters from non-volatile memory
    ; pause.g
    ; called when a print from SD card is paused
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 26 2020 16:14:59 GMT+0200 (MitteleuropƤische Sommerzeit)
    M83            ; relative extruder moves
    G1 E-10 F3600  ; retract 10mm of filament
    G91            ; relative positioning
    G1 Z5 F360     ; lift Z by 5mm
    G90            ; absolute positioning
    G1 X0 Y0 F6000 ; go to X=0 Y=0
    EndGcode when print is finish
    M104 S0
    M140 S0
    ;Retract the filament
    G92 E1
    G1 E-5 F200
    G1 X5 Y300 F6000
    G1 Z290 F500
    M300 S290 P1000
    M84
    M98 P"/macros/LED/LED_gruen"
    G4 S30
    M98 P"/macros/LED/LED_weiss"
    G4 S120
    M98 P"/macros/LED/LED_aus"
    I doun't have a cancel.g.
    I use RRF 3.2 stabel.
  • is there an error message in the console?
  • No there is no error on console
  • M122
    RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
    Board ID: 08DJM-956L2-G43S8-6JTDG-3SJ6P-KB0UG
    Used output buffers: 1 of 40 (10 max)
    Static ram: 149788
    Dynamic ram: 63788 of which 64 recycled
    Never used RAM 145192, free system stack 124 words
    Tasks: Linux(ready,71) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,346) CanClock(blocked,352) TMC(blocked,19) MAIN(running,717) IDLE(ready,19)
    Owned mutexes: HTTP(MAIN)
    Last reset 02:30:34 ago, cause: software
    Last software reset at 2021-01-13 09:03, reason: User, none spinning, available RAM 145192, slot 1
    Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
    Error status: 0x00
    Aux0 errors 0,0,0
    Aux1 errors 0,0,0
    MCU temperature: min 34.4, current 35.1, max 42.7
    Supply voltage: min 24.3, current 24.7, max 25.3, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
    Driver 0: position 0, standstill, reads 17103, writes 43 timeouts 0, SG min/max 0/0
    Driver 1: position 0, standstill, reads 17103, writes 43 timeouts 0, SG min/max 0/0
    Driver 2: position 85642, standstill, reads 17091, writes 55 timeouts 0, SG min/max 0/0
    Driver 3: position 0, standstill, reads 17091, writes 55 timeouts 0, SG min/max 0/0
    Driver 4: position 0, standstill, reads 17092, writes 55 timeouts 0, SG min/max 0/0
    Driver 5: position 0, standstill, reads 17103, writes 44 timeouts 0, SG min/max 0/1023
    Date/time: 2021-01-13 11:34:33
    Slowest loop: 180.92ms; fastest: 0.04ms
    === Storage ===
    Free file entries: 10
    DMs created 125, maxWait 1171149ms, bed compensation in use: mesh, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 19083, completed moves 19083, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 11], CDDA state -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    Telnet is idle in state(s) 0
    File* is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Queue* is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon is idle in state(s) 0
    Aux2 is idle in state(s) 0
    Code queue is empty.
    === CAN ===
    Messages queued 36177, send timeouts 81349, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
    === SBC interface ===
    State: 4, failed transfers: 0
    Last transfer: 2ms ago
    RX/TX seq numbers: 44017/44017
    SPI underruns 0, overruns 0
    Number of disconnects: 2, IAP RAM available 0x2c8a8
    Buffer RX/TX: 0/0-0
    === Duet Control Server ===
    Duet Control Server v3.2.0
    Code buffer space: 4096
    Configured SPI speed: 8000000 Hz
    Full transfers per second: 38.93
    Maximum length of RX/TX data transfers: 2672/1504
  • @Heartleander81 said in Problem after cancel print:
    I doun't have a Cancel.g to time.
    What does that mean?
    Is the code you posted in cancel.g?
    In the code posted you are setting the temps to zero. When you try to print again do you restore the correct settings?
  • The last config is my end GCode afte the print.
  • In the code posted you are setting the temps to zero. When you try to print again do you restore the correct settings?
    I doun't know. I start the gcode. The bed heats up, the nozzle heats up, then make the printer his homing. Then extrude any filament. After this doun't come filament out the nozzel.
    There is a picture oft the DWC .
    Print is at layer 71 and filament only used 0.4mm, but must ~100mm used at this layer hight.
    I hope you understand what i mean. My english is not the best šŸ˜Š
  • Hi,
    This is a long shot but create an empty cancel.g file and see if that makes a difference.
  • @fcwilt Will test it after work. But just think that I have an error somewhere in a file. After successfully printing the file, the problem was that the next print did not work either. It only worked again after restarting the Pi. That's only since I updated from 3.1.1 to 3.2.0
  • Moderator
    Can you try describing again what exactly this means? I'm having a hard time understanding the problem.
    Does the printer try to resume the print but the extruder motor doesn't turn?
    Does it just sit there?
    Is the heater at temp at that point?
  • @Phaedrux
    I start a print.
    For example, a component comes loose.
    Then press pause and release the pressure.
    Change something on the slice or try to reprint.
    Then nothing is extruded during printing.
    When I restart the Pi, it prints normally.
    But today I was able to determine that this problem also occurred even after a successful print. That's only since the update from 3.1.1 to 3.2.0
    After Bed and Nozzle is on temp make my Printer Homing.
  • Moderator
  • Sorry. Fu.. Translator. I doun't have check before copy and past.PRESS pause and then cancel i the print
    I have a Video on youtube
    https://youtu.be/FWr_m28CsAc
  • Moderator
    Did you try creating the missing cancel.g?
  • This post is deleted!
  • Is the same with empty cancel.g
  • Moderator
    Do you have a T0 command in your slicer start gcode?
    Is your tool still selected after canceling?
    Can you try putting some commands in your cancel.g?
    Example:
    ; cancel.g
    ; Run when the print is paused, and then canceled.
    G10 P0 R0 S0		; Set hotend temp to 0
    M140 S0			; Set bed temp to 0
    M106 S255 		; Fan at 100 to cool nozzle and bed
    M220 S100		; Set speed factor back to 100% in case it was changed
    M221 S100		; Set extrusion factor back to 100% in case it was changed
    M290 R0 S0              ; clear babystepping
    G28 XY			; home XY
    M84			; turn off steppers
    G4 S60			; wait 1 minute for nozzle to cool
    M107			; turn off the fan
  • Now is working with this config.
    Can you tell me why?
    What config? Did you mean to post one?
  • @fcwilt i mean the config post from phaedrux
  • Moderator
    You mean you added those commands to cancel.g?
    I'm thinking there is an issue with missing or blank cancel.g files and the firmware isn't doing the expected default behaviour.
    Thanks for confirming that adding a cancel.g with commands allows it to work. I'll flag this for further investigation.
  • @Phaedrux I doun't now why, but on second test, the same bevore. I test at saturday more cycles. I think the problem is at my side.
    I give you Feedback at saturday night ore sunday morning.
