Solved IMPORTANT ISSUE with bed temp controller
@fcwilt you where right (before deleting your comment) but my config was set as using bang bang..
@jrockland said in IMPORTANT ISSUE with bed temp controller:
@Luke-sLaboratory hmm wait if I look at my config file bang bang IS activated..
Even with the slow rate of "bang bank" a mechanical relay is not a good choice.
I saw that someone had already mentioned that issue so I tried to delete mine.
@fcwilt true, probably why they where changed on the other machines
Good news tho, the 3/4 inch aluminum bed survived (still straight). the only thing that died is the embedded magnets (n52).. Ill get those replaced then work on the gcode once the board is back.
reprap is getting better and better, and those 6hg/3hc boards are really solid. we blown multiple motors and heaters core (I remember something crashed IN the board hard enough that the thin metal door bended and shorted the board) and it still running strong.
I tried to delete the post as it look like bang bang was deactivated, so not a firmware issue. anyway probably my bad when I wrote the gcode.
