    Bltouch trigger value problem
    • sigourosandreasundefined
      sigourosandreas
      I have installed a BLtouch to the duet wifi running RRF3.2 but I get a Z probe trigger value 1000 on the DWC. Thus I am geting an error when I try to home the Z.
      I have checked the wiring and it is doing correctly the self-test, pin down, pin up commands. But the DWC shows 1000 for value.
      My deploy probe file is:
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Jan 03 2021 18:41:40 GMT+0200 (Χειμερινή ώρα Ανατολικής Ευρώπης)
      M280 P0 S10 ; deploy BLTouch
      My retract probe file is:
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
      My config file is:
      M550 P"ToolChanger" ; set printer name
      M669 K1 ; select CoreXY mode
      ;M587 S"andreas" P"as2138774" ; WiFi Settings
      M552 S1 P"andreas" ; Enable WiFi Networking
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes forwards (X axis)
      M569 P1 S1 ; physical drive 1 goes forwards (Y axis)
      M569 P2 S1 ; physical drive 2 goes forwards (Z axis)
      M569 P3 S1 ; physical drive 3 goes forwards (E0)
      M569 P4 S1 ; physical drive 4 goes forwards (Coupler)
      M584 X0 Y1 Z2 E3 C4 ; set drive mapping
      M350 E16 C8 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E420.00 C100.00 ; set steps per mm
      M566 X400.00 Y400.00 Z10.00 E100.00 C2.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X16500.00 Y16500.00 Z1000.00 E5000.00 C5000 ; set maximum speeds (mm/min)
      M201 X4000.00 Y4000.00 Z400.00 E2500.00 C500.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1000 E1500 C400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-7.5 Y0 Z0 C0 S1 ; set axis minima
      M208 X325 Y322 Z325 C500 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M574 C1 S3 ; configure sensorless endstop for low end on C
      ;Stall Detection
      M915 C S5 F0 H200 ; coupler
      G31 P25 X-15.3 Y49.47 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X2.5:325 Y49:315 S25 ; define mesh grid
      M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel 5 on the Duex board
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S140 ; set temperature limit for heater 0 to 140C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q100 ; create fan 1 on pin fan1 and set its frequency
      M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
      M950 F2 C"fan2" Q80 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 H2:3 L0.15 X110 B0.3 T40:70 ; set fan 2 value
      G10 P0 X0 Y0 Z0 ; reset tool 0 axis offsets
      G10 P0 R0 S0 ; reset initial tool 0 active and standby temperatures to 0C
      ;tool offsets - stock
      ;G10 P0 X55 Y322 Z-5 ; T0
      ; Filament diameter
      M404 P0 N1.75 D0.4
      ;deselect tools
      T-1
      ;M572 D0 S0.05 ; pressure advance T0
      M501 ; read stored parameters
      M80 ; Turns on the ATX power supply
      M81 ; Turns off the ATX power supply
      • Vetiundefined
        Veti
        post a picture of your wiring
          sigourosandreas
          My fault. Bad wiring
            Phaedrux Moderator @sigourosandreas
            @sigourosandreas said in Bltouch trigger value problem:
            Meaning it's working now?
            sigourosandreasundefined 1 Reply Last reply Reply Quote 0
              sigourosandreas @Phaedrux
              @Phaedrux yes, just changed the wiring from paneldue pins to probe on the board. You ca see my mistake on the photo
