    PrusaSlicer DWC disconnect on upload/test.
    Duet Web Control
    • Dkosundefined
      Dkos
      Hello, not sure if I should post this here or over the PrusaSlicer support, but I am giving it a shot in case anyone else has experience something similar since I cant seem to find anything related on the web.
      The subject is pretty much self-explanatory, every time I upload or test the connection from PrusaSlicer to the DWC I lose connection. Then I have to refresh, re-enter password and so on. It is annoying on the long run.. PrusaSlicer reports connection successful, and if I upload, the files are indeed uploaded, but then of course a disconnection follows.
      This does not seem to be an issue when uploading from another slicer (e.g Cura).
      System overview: Duet2Wifi on RRF3.2 with DWC 2.0.4 and Wifi server 1.25.
      Has anyone experienced something similar?
      • gloomyandyundefined
        gloomyandy
        What version of PrussaSlicer?
        Do you have the same problem when using DWC 3.2?
        • Vetiundefined
          Veti
          @Dkos said in PrusaSlicer DWC disconnect on upload/test.:
          DWC 2.0.4
          that version is not mean for firmware version 3.
          please update to dwc 3.2
          • Dkosundefined
            Dkos
            Thank you both for the replies. I just updated to DWC 3.2. Almost good news.
            I do not entirely lose connection. Meaning it gets a connection interrupt, but it reconnects automatically. No need to re-enter password so thats good.
            On the other hand something is still going wrong there, i get the following warning upon upload:
            Connection interrupted, attempting to reconnect...
            JSON.parse: unexpected character at line 1 column 1 of the JSON data
            But updating indeed fixed the annoying part of the issue, thanks!
            • PCRundefined
              PCR
              Which Prusa slicer? There was a bug in 2.2.
              • Dkosundefined
                Dkos
                Yes apologies I forgot to answer that. I am using PrusaSlicer v2.3 on Linux. But I also experienced the same issue with Windows when I was on RRF2.05.
