    Duet2 Wifi randomly(?) reboots
    • Jasperundefined
      Jasper
      Since a few days I start to notice my printer suddenly reboots randomly.
      Today it happend during a 6h print. I haven't had any issues the last year with the current version and hardware I'm using.
      M122 code results below. What does the reason for the software reset mean?
      Also, is there a way to continue the print when this happens? A bit annoying to restart a 6h print..
      Software info:
      Firmware Version: 2.02RC5(RTOS) (2018-11-28b1)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.5
      Kind regards,
      Jasperc
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC5(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6JTD8-3SJ6S-TZ8NH
      Used output buffers: 1 of 20 (8 max)
      Static ram: 27284
      Dynamic ram: 98524 of which 0 recycled
      Exception stack ram used: 280
      Never used ram: 4984
      Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,3548) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:02:58 ago, cause: power up
      Last software reset at 2020-12-22 17:42, reason: User, spinning module GCodes, available RAM 4716 bytes (slot 2)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 33.3, current 33.4, max 34.6
      Supply voltage: min 11.1, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2021-01-16 17:28:38
      Cache data hit count 664734732
      Slowest loop: 2.10ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      Movement lock held by null
      http is ready with "M122 " in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 14.10ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 84:f3:eb:83:38:2c
        WiFi Vcc 3.34, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 16192
        WiFi IP address 192.168.178.53
        WiFi signal strength -67dBm, reconnections 0, sleep mode modem
      • Vetiundefined
        Veti
        @Jasper said in Duet2 Wifi randomly(?) reboots:
        update to at least 2.05.1
          Your firmware version is 2 years old. Many bugs have been fixed since.
          If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
          That will get your firmware and DWC up to date.
          https://configtool.reprapfirmware.org/Start
          For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3 as many things have changed in the configuration.
          • Jasperundefined
            Jasper
            Thanks both, I will update the firmware and see if it is due to a bug that is being triggered after 2 years. I haven't updated earlier, because "if it ain't broke, don't fix it".
              Phaedrux Moderator @Jasper
              Yes I think updating will help.
