    Mirror image and homing on x axis
    140
    • ortondale
      ortondale last edited by
      Hi all
      Any forum member who can help point me in the right direction, it would be much appreciated.
      The printer produces components with a mirrored x axis, (y axis is ok).
      At the moment the 0, 0, position is to front right side, looking from the front of the printer, the front left side is what is required. When I do get it to home and read 0, 0 in the left corner the + and – readings are the wrong way round reading –towards the bed not +.
      Motor 1 left side front, motor 2 right side front.
      Maximum axis travel set to x270, y270.
      At the moment x homing sensor is to the left and is set high, (this in practice should be set to low)
      On homing this gives the position x=270 giving a mirror image (0 being required).
      If the sensor is set to low side (as it should be) it will home to give x=0, but the bed side to the right then reads 0 to-270 (not the required 0 to 270)
      I have tried all combinations in config. g, homex.g and homeall.g without a result.
      All suggestions will be welcome
      Board: Duet Maestro 1.0
      Firmware: RepRapFirmware for Duet 2 Maestro 2.05.1 (2020-02-09b1)
      Duet Web Control 2.0.4
      ; Configuration file for Duet Maestro (firmware version 2.03)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 23 2020 15:16:31 GMT+0100 (Central European Standard Time)
      ;M83 ; ...but relative extruder moves (will give negative retract moves)
      M82 ; .. but absolute extruder moves (will give positive retract moves)
      M550 P"HyperCube Printer" ; set printer name
      M667 S1 ; select CoreXY mode
      M918 P1 E4 F2000000 ; configure direct-connect display
      M551 P"hypercube" ; set password
      M552 P192.168.1.171 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.1.254 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X80 Y80 Z400.00 E415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z120.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z20.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z900 E500 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X270 Y270 Z270 S0 ; set axis maxima
      M574 X2 Y2 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M558 P9 F100 H5 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
      ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X30 Y0 Z0.798 ; set Z probe trigger value, offset and trigger height
      M557 X60:270 Y30:260 S25 ; define mesh grid
      M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
      M143 H0 S80 ; set temperature limit for heater 0 to 80C
      M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
      M143 H1 S240 ; set temperature limit for heater 1 to 240c
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"E3D V6" D0 H1 F0 ; define tool 0
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H2 Z5 F3000 ; lift Z relative to current position
      G1 H1 X255 Y275 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X255 ; home X axis
      G1 H1 Y275 ; home Y axis
      G1 X-5 Y-5 F3000 ; go back a few mm
      G1 H1 X255 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y275 ; then move slowly to Y axis endstop
      G90 ; absolute positioning
      G1 X165 Y135 F3000 ; go to first bed probe point and home Z
      G29 S1 ; load mesh map from sd card
      ;G91 ; relative positioning
      ;G1 Z5 F50 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homex.g
      ; called to home the X axis
      G1 H1 X255 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X-5 F3000 ; go back a few mm
      G1 H2 Z-5 F3000 ; lower Z again
      • Veti
        Veti last edited by Veti
        @ortondale said in Mirror image and homing on x axis:
        change to
        M574 X1 Y2 S1 ; set active high endstops
        also see
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
        ortondale 1 Reply Last reply Reply Quote 1
        • fcwilt
          fcwilt last edited by fcwilt
          Where are your end stop sensors located?
          There is nothing that says a sensor should be located on the "low side".
          The purpose of the sensor is to allow the firmware to determine that an axis is in a known position. That can be at/near the axis min or max - it makes no difference - either will work.
          The position of X=0 and Y=0 is another issue entirely and they are not determined by where the sensors are.
          On my printer the sensors are near X min and Y max but X=0 and Y=0 are in the center of the bed - which is where I prefer it.
          ortondale 1 Reply Last reply Reply Quote 0
          • ortondale
            ortondale @Veti last edited by
            @Veti Hi Veti
            When set to (M574 X1 Y2 S1 ; set active low endstops)
            I get the results as per second diagram
            Moving left to right towards centre of bed give a minus reading instead of a plus reading.
            That the problem
            Veti 1 Reply Last reply Reply Quote 0
            • Veti
              Veti @ortondale last edited by
              That the problem
              the movement part that you need to fix is covered in the wiki page i linked
              • ortondale
                ortondale @fcwilt last edited by
                @fcwilt Hi Frederick
                My sensors are in the same position as your printer, it’s the X=0 position on my printer that needs flipping so the axis is not mirrored. You have X=0 in the centre of your bed, the right side of the X=0 will read a plus movement and the left side will read minus. My printer is the opposite and I cannot work out how to reverse it.
                fcwilt 1 Reply Last reply Reply Quote 0
                • fcwilt
                  fcwilt @ortondale last edited by fcwilt
                  Did you change the M569 settings for the axis?
                  • ortondale
                    @fcwilt Do you mean M569 don’t think M596 is in the code?
                    Yes, changed 0P and 1P around combination of forwards and backwards with no result.
                    I’m well into my 70,s and the minds not as sharp as it used to be so I might be missing an obvious error in the set up. I will just have to remember to keep flipping the x axis at the slicing stage until I can find the problem. Thanks for your time, much appreciated.
                    Veti fcwilt 2 Replies Last reply Reply Quote 0
                    • Veti
                      you really need to read the page i linked.
                      • ortondale
                        @Veti Been over the linked page but will revisit again to make sure, might have to get back to you if I can’t figure it out
                        • fcwilt
                          Sorry - a typo - yes M569.
                          So you tried M569 P0 S0?
                          • ortondale
                            @fcwilt Yes, it created a diagonal movement to the right front
                            • fcwilt
                              My bad - I missed that you have a CoreXY machine.
                              In that case it gets a bit tricky.
                              On my Mark Forged style printer I had to use M669 (instead of M667) with the appropriate parameters to get the motors to move correctly.
                              The documentation for M669 discusses how to set the parameters but in my case I determined them by trial and error.
                              • Veti
                                Veti last edited by
                                If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
                                • ortondale
                                  @Veti The head moved diagonal to right front corner X=0 Y=0 with P0 S0
                                  P0 S1 is the line I’m running which gives the mirror
                                  • Veti
                                    Veti last edited by
                                    have you swapped the motor connections?
                                    • fcwilt
                                      fcwilt @Veti last edited by
                                      @Veti said in Mirror image and homing on x axis:
                                      That would work as well or determine the correcting settings for M669 and use it in place of M667.
                                        https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue?_=1610937338221
                                        • ortondale
                                          Problem Solved
                                          Switched motor plugs around on X and Y
                                          Reversed motor direction
                                          Changed end stop to X1
                                          Home X axis changed from G1 H1 X255 to G1 H1 X-255
                                          Go back a few mm changed from X-5 to X5
                                          Reset probe point and mesh bed configuration
                                          All is well
                                          Big thanks to Veti, fcwilt and Phaedrux (moderator) for the advice pointing me in the right direction. Great Forum
                                          fcwilt 1 Reply Last reply Reply Quote 1
                                          • fcwilt
                                            @ortondale Very glad to see you got it sorted - good work.
