IR Sensor is not homing the Z-Axis correctly
IR Height Sensor
537
  • undefined
    juanito16k
    i have trouble to home my Z-Axis. I calibrated my config according to the guide "Test and calibrate a Z probe" with the Paper-Method so i use G92 to have Z0 where the nozzle pins the Paper and then i probe the bad and get between 1.25 and 1.3 mm which i put in to my config. Wenn i move the bad then back to Z0 and i put a Paper between the Paper will pin again.
    Wenn i then home the Z-Axis again for example after switching the power off shortly then the Z-Axis homes again to Z6,25 for example but when i move the bad to Z0 the Paper wont pin again actually there is a big gap between nozzel and bad.
    in the first run befor homing again, for probing the bad, the prob goes really near the bad and trigger at 625 on the probe field in the web interface. But in the second homeing it just probe 100 and doesnt get anyway near as in the first probing?
    Following i send my config and home, i hope someone can help me.
    ; generated by RepRapFirmware Configuration Tool v3.2.0 on Wed Jan 06 2021 00:32:39 GMT+0100 (Mitteleuropäische Normalzeit)
    M550 P"BLVCube" ; set printer name
    M669 K1 ; select CoreXY mode
    M551 P"jaw89jaw89" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X330 Y300 Z600 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P1 X0 Y0 Z1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y-20 Z1.265 ; set Z probe trigger value, offset and trigger height
    M557 X50:330 Y50:300 S30 ; define mesh grid
    M307 H0 A74.3 C590.5 D=3.0 V24.2 B0 ; Set PID for heated bad
    M307 H1 A279.5 C105.0 D6.9 V23.7 ; disable bang-bang mode for heater and set PWM limit
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H1 X-305 Y-285 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-305 ; home X axis
    G1 H1 Y-285 ; home Y axis
    G1 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-285 ; then move slowly to Y axis endstop
    G90 ; absolute positioning
    G1 X200 Y160 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
    undefined 1 Reply Last reply 16 Jan 2021, 21:38 Reply Quote 0
    • undefined
      fcwilt @juanito16k
      @juanito16k said in IR Sensor is not homing the Z-Axis correctly:
      What command are your issuing to do that?
      • undefined
        juanito16k
        undefined 1 Reply Last reply 16 Jan 2021, 22:02 Reply Quote 0
        • undefined
          fcwilt @juanito16k
          That is for configuring the probe.
          To actually probe you use one of the G30 variants.
          So which variant did you use?
          Thanks.
          undefined 1 Reply Last reply 17 Jan 2021, 13:49 Reply Quote 0
          • undefined
            JayJay
            As you look to be on RRF3
            The M558 command switch "probe type" needs to be set to P8 instead of P1
            IR Probe
            With Duet 3 main board, expansion board or tool board: Connect the VCC, GND and OUT pins of the sensor to 3.3V, GND and IN respectively on an IO probe connector, and select mode 8 in the M558 command.
            • undefined
              juanito16k
              okay i did that but my Z0 stays like in the picture after homing againIMG_20210117_112621.jpg
              • Vetiundefined
                Veti
                your surface is reflective and not dull.
                that is not good for ir.
                • undefined
                  juanito16k @fcwilt
                  @fcwilt G30 S-1 ?
                  undefined 1 Reply Last reply 17 Jan 2021, 15:18 Reply Quote 0
                  • undefined
                    fcwilt @juanito16k
                    @fcwilt G30 S-1 ?
                    OK that variant is used to report what the Z trigger height is.
                    To set the Z=0 datum you want to use just G30.
                    undefined 1 Reply Last reply 17 Jan 2021, 15:26 Reply Quote 0
                    • undefined
                      juanito16k @fcwilt
                      @fcwilt thank for the respones, i actually do that in my homing file
                        Place a plain piece of paper on your bed and try testing again. As Veti says, your bed may not be very suitable for an IR sensor.
                        • undefined
                          juanito16k
                          i think the problem was, that i had the printer right besight a window where a lot of light entered i moved the printer to a darker place and haddent had any further problems
                            Ah yes, that would definitely do it.
                            1 out of 13
