    Did I already kill my 1st duet?
    • Layer_Shiftundefined
      Layer_Shift
      This issue has been rtesolved.
      I’m setting up my first set board. Did I kill it already? I hooked the power from the power supply up backward. Found the problem and fixed it. Now the board lights up but it does not show up on my router and I can’t get it to connect to Yat anymore. Is there anything I can do to salvage the board?
      Update Edits:
      all 3 fuses are good.
      Resolution: I had a normally closed and stop circuit wired into the connector incorrectly. It was causing fault on the 3.3 V system. Everything seems to be working now
      • ktapperundefined
        ktapper
        You check all the fuses?
          Layer_Shift
          Just checked all 3 fuses, and they are all good. Thet have the same voltage on both sides when on.
            Layer_Shift
            I disconnected everything except the 24v in and the USB, and I can connect again, and now my 3.3v green led is on. I will try reconnecting everything one at a time to try and find the problem
            • ktapperundefined
              ktapper
              Power it with just the USB....see if everything is working
                Layer_Shift
                I had a normally closed and stop circuit wired into the connector incorrectly. It was causing fault on the 3.3 V system. Everything seems to be working now, I appreciate everyone who took the time to read this
