    Can I print ABS on a PLA part?
    • o_lampe
      o_lampe last edited by
      Hi folks,
      I have finished my first black PLA-roll on a huge 24h print.
      I wanted to change to another, but only have a roll of black ABS left, would it stick on PLA?
      Or do I have to finish the print with yellow PLA?
      • Veti
        Veti last edited by
        abs will need different print settings.
        and as far as i understand it it will not bond.
        • o_lampe
          I agree, the hotend temp is higher. (easy fix)
          But would I need to raise the bed temp?
          The print is already 60mm high, so warping should be no issue, but the bond must be strong enough....
          • Veti
            Veti last edited by
            the bonding is poor. that is why some people use pla for support on abs prints.
            o_lampe 1 Reply Last reply Reply Quote 0
            • o_lampe
              o_lampe @Veti last edited by
              @Veti thanks!
              OK, it's yellow PLA then...
              stupid me, I should've inspected it before I started the print.
