IDEX and Z Offset
  • Hello,
    Traduction from french :
    I have a Cartesian setup with a Duet2Etehernet Firmware 2.05.1, a z-probe, 4 independent Z screws, and 2 independent X carriages (IDEX).
    I have an offset of 6.5mm between the 2 nozzles.
    So I put a G10 P1 Z6.5
    When I use tool 0, I set the Z to 1, then I change to tool 1, it goes to 7.5mm, normal, but I can't go below 6.5mm anymore.
    Do I have a problem with my configuration, or is it a bug?
    Thanks,
    Here is my config .g
    config .g
  • Moderator
    I don't see the G10 P1 Z6.5 in your config.g. Are you sending that separately?
    M563 P0 D0 H1 F0; define tool 0
    M563 P1 D1 H2 X3 F2; define tool 0
    ; Nozzle offsets
    G10 P0 X0 Y0 Z0 R0 S0
    G10 P1 U0 Y0 Z0 R0 S0
    Can you post your tool change files as well?
  • Perhaps you have to flip the sign of the offset. G10 P1 Z-6.5. Test with caution.
  • @Phaedrux Yes,
    Thanks,
    yes, i tried two methods, once in config.g and once by gcode terminal.
    here is my tool change file :
    tfree0.g
    M83 ; relative extruder movement
    G1 E-2 F3600 ; retract 2mm
    M106 S0           ; turn off our print cooling fan
    G91 ; relative axis movement
    G1 Z3 F500 ; up 3mm
    G90 ; absolute axis movement
    G1 H2 X-200 F6000 ; park the X carriage at -100mm
    tfree1.g
    G1 Z3 F500 ; up 3mm
    G1 H2 U965 F6000 ; park the U carriage at +950mm
    tpost0.g
    M106 R2           ; restore print cooling fan speed
    M116 P0 ; wait for tool 0 heaters to reach operating temperature
    G1 E2 F3600 ; extrude 2mm
    tpost1.g
    M116 P1 ; wait for tool 1 heaters to reach operating temperature
  • @bot
    Thanks,
    I already tried with -6.5, it's not working ...
  • Moderator
    Can you send M98 P"config.g" and M122 and post the results?
    It may be worth updating your firmware and config files for RRF3.
    If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
    That will get your firmware and DWC up to date.
    https://configtool.reprapfirmware.org/Start
    For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3 and then add your customizations for IDEX again.
    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
  • M98 P"config.g"
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is enabled on port 23
    Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 953C.
    m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later + DueX5
    Board ID: 0JD0M-9P6M2-NWNS4-7J9D4-3SD6Q-1V1ZL
    Used output buffers: 3 of 24 (17 max)
    Static ram: 25712
    Dynamic ram: 93552 of which 0 recycled
    Exception stack ram used: 320
    Never used ram: 11488
    Tasks: NETWORK(ready,628) HEAT(blocked,1176) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:33:40 ago, cause: power up
    Last software reset at 2021-01-20 08:35, reason: User, spinning module GCodes, available RAM 11488 bytes (slot 1)
    Error status: 0
    Free file entries: 9
    SD card longest block write time: 7.4ms, max retries 0
    MCU temperature: min 32.8, current 33.1, max 33.4
    Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Date/time: 2021-01-21 09:21:18
    Slowest loop: 10.83ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 27.45ms; fastest: 0.06ms
    HTTP sessions: 2 of 8
    Interface state 5, link 100Mbps full duplex
    I wanted to try to correct before deciding to switch to RRF3, but if I can't find it, I will upgrade.
    Thanks
  • Moderator
    Well there has been a year of bug fixes since 2.05 so it would be nice to test on current code base.
  • I upgraded everything, but that doesn't change anything ...
  • there are a lot of bugfixes in rrf3 regarding offset of tools
  • I look in bugfixes, but not find.
    Here is the error message after tool change :
    Error: New tool too close to Z axis limit. Aborting tool change
  • @mbtobeca said in IDEX and Z Offset:
    see https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
    search for offset
  • In fact, I did find this page, but I couldn't find anything about my problem. I even believe that it is a desired security. I saw that he was talking about the max limit in Z, but not the min limit:
    "If a tool change is requested but changing tool would cause the Z max limit to be exceeded because of the changed tool Z offset, the tool change is now aborted"
    Thanks to try help me
  • Moderator
    So you are on 3.2 now?
  • yes i'm on 3.2
  • I hit the same issue when I config as below.
    Start script:
    T1
    G28
    T0
    Root cause:
    Reading from code is due to I am using zmin as probe, however I have zmax endstop too. And my zmax saved is small then actual.
    Solution:
    However I don't want to config zmax again and again.
    comment the code and build without checking
    Gcodes4.cpp
    // auto currentTool = reprap.GetCurrentTool();
    // if (currentTool != nullptr)
    // const float newZPos = (moveBuffer.coords[Z_AXIS] - currentTool->GetOffset(Z_AXIS));
    // if(newZPos > platform.AxisMaximum(Z_AXIS) || newZPos < platform.AxisMinimum(Z_AXIS))
    // gb.MachineState().feedRate = toolChangeRestorePoint.feedRate;
    // doingToolChange = false;
    // gb.MachineState().SetError("New tool too close to Z axis limit. Aborting tool change");
    // AbortPrint(gb);
    // gb.SetState(GCodeState::checkError);
    // break;
  • How are you planning on getting each nozzle down to where they need to be to print a layer when they are 6.5mm offset in Z?
    Won't one need to be 6.5mm BELOW the level of the print to get the other one down to the level of the print?
    I'm probably misunderstanding something. (as usual!) 🙂
  • I think this is unnecessary logic. Why I can't switch tools when I am using the zmax endstop? That is the problem in that logic.
  • if it is zmax already, tools are far enough to the buildplate, why need such stupid logic.
