    PanelDueFirmware 3.2.9 released
    PanelDue
    365
    • wilriker
      wilriker Moderator last edited by
      Once again a bugfix release to address regressions introduced in the previous version.
      Version 3.2.9
      Upgrade Notes:
      • This release is compatible with RepRapFirmware 3.2 or later.
      Limitations
      • Due to the lack of RAM this build will not run on version 1 or early version 2 PanelDue boards that use the ATSAM3S2B chip.
        • Version 1.0, 1.1 and earlier v2 PanelDue: ATSAM3S2B processor (64MHz, 32kb RAM, 128kB flash) - these are the ones that the new firmware probably won't run on.
        • Version 2 PanelDue manufactured from August 2016: ATSAM3S4B processor (64MHz, 48kb RAM, 256kb flash). Will run the new firmware, but not as fast as version 3 will.
        • Version 3 PanelDue, including all 5i and 7i: ATSAM4S4B processor, 120MHz, 64kB RAM, 256kb flash. Will run the new firmware.
      Changed:
      • Removed obsolete code
      • Replaced custome code by C-standard impl
      Bug fixes:
      • Fix heater state of bed heater being temporarily applied to all but the first tool
      • When STOP button was pressed PanelDue never really got into "Initializing" state again
      • When OM key "tools" updated all tools would temporarily show 0.0°C as current temp
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2.9
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      Stephen6309 1 Reply Last reply Reply Quote 1
      • wilriker
        I just replaced all release binaries because accidentally the uploaded binaries identified themselves still as version 3.2.8.
        Manuel
        My Tool Collection
        • brisma
          brisma last edited by
          Hi, I pushed a PR for the italian language 🙂
          • Stephen6309
            Stephen6309 @wilriker last edited by
            @wilriker Duet 3 Mini 5+ with PI4 and v3 4.3" Paneldue. Doesn't upgrade when uploading zip file and M997 S4 fails, Error: M997: Network-related commands are not supported when using an attached Single Board Computer.
            The zip file works fine with my 6HC w/PI4 and v3 7" Paneldue.
            Both Duets have 3.2.
            wilriker 1 Reply Last reply Reply Quote 0
            • wilriker
              wilriker Moderator @Stephen6309 last edited by wilriker
              @Stephen6309 Hi. I think you reported that earlier and I missed to reply. Sorry for that. This is actually not a PanelDueFirmware problem but a bug in RepRapFirmware. I will have a look. Thanks for reporting.
              EDIT: I found and fixed the problem. Should be working in the next RepRapFirmware release.
              Manuel
              My Tool Collection
              • garyd9
                garyd9 last edited by
                @wilriker
                I'm noticing what appears to be a cosmetic bug with 3.2.9 (and likely on earlier releases) "Print Again" button on the 'print' tab/page. It seems like the PanelDue firmware isn't erasing that button when it's not longer applicable (such as when starting a print. The result is that when a print job ends and a new (not repeated) print job is started, the print tab/page progress bar is covering parts of the "Print Again" button, but there are still remnants of the no longer applicable button still on the display above and below the progress bar.
                If I switch from the print tab/page to the control tab/page and then back, the remnants of the "print again" button disappear.
                I'm using: PanelDue 7i with the 3.2.9 "PanelDueFirmware-5.0i-7.0i-nologo" precompiled binary (for the 7i/5i) that was uploaded to the paneldue via RRF/DSF 3.2 new ability to update the PanelDue firmware. I can't be 100% certain, but I believe I started the print job from the PanelDue itself as a new print job (not a repeat.)
                "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                • wilriker
                  wilriker Moderator @garyd9 last edited by
                  @garyd9 Thanks for reporting. I'll check that the next time I look at PanelDueUpdater.
                  Manuel
                  My Tool Collection
                  garyd9 1 Reply Last reply Reply Quote 0
                  • garyd9
                    garyd9 @wilriker last edited by
                    @wilriker
                    Here's an image showing it:
                    wummelfrosch 1 Reply Last reply Reply Quote 0
                    • wummelfrosch
                      wummelfrosch @garyd9 last edited by
                      @garyd9
                      Hy, this PRoblem I also have 🙂
                      1.Modified Prusa Style Printer:Duet2 Eth, 24V MW 750W, E3D Chimera+ Dual Wakü, 2x Bondt QR 500mm Bowden, 2x FTS 2.0 Sensor, BLTouch , 15mm CTC Linear Rails Y-Axis, 2xKGT-12x4 Z-Axis,10mm Linear X-Axis, Laing DDC Pump,120mm Radiator 2.Bcn3d Sigma R19
                      • wilriker
                        I have now released PanelDueFirmware 3.2.10. Please continue in this thread.
                        Manuel
                        My Tool Collection
