BLtouch does not work after changing to DUEX5 board
I've been trying to solve this by searching on the forum but I can not find any answers.
Before I had a Duet Wifi + a duex2 board, now I upgraded to a Duex5 board and suddeny the BLTouch does not work.It's connected in the exact same place as it was on the Duex2 board, is there anything I need to change in the config when using a duex5 instead of a duex2?
Where is it physically connected? Photo?
Test the continuity of the wire?
Post your config.g and the results of M122 and M98 P"config.g" -
@Phaedrux Hi!
It's connected in the PWM_1 on the Duex 5 + the "Ground" and "Z_PROBE IN" on the Duet Wifi.
I got this in my config.g:
; General preferences G21 ; work in millimeters G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M584 X6 Y1 Z2:5:4 E3 ; set 3 Z drivers M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M569 P5 S0 ; Drive 5 goes backwards M569 P6 S1 ; Drive 6 goes forwards M669 K0 Y-1.005:1:0: ; set Y to react with X ; Defining X and Y coordinates of the leadscrews M671 X-80:580:580 Y245:490:0 S5 ; leadscrews at front right, rear right and middle left M350 U16 X16 Y16 E16 Z16 I1 ; Configure microstepping with interpolation M92 X133.33 Y242.00 Z200 E415.00 ; Set steps per mm M566 X900.00 Y900.00 Z20.00 E200.00 ; Set maximum instantaneous speed changes (mm/min) M203 X15000.00 Y15000.00 Z600.00 E3600.00 ; Set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z30.00 E3000 ; Set accelerations (mm/s^2) M906 X1000.00 Y1500.00 Z1000.00 E700.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ;Energize Z steppers M906 I100 ; prevent idle current reduction G91 ; relative mode G1 S2 Z0.1 ; energize all 3 motors G90 ; absolute mode ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X500 Y500 Z750 S0 ; Set axis maxima ; Endstops M574 X1 S0 ; Set active low endstops M574 Y2 S1 ; Set active high endstops ; Pressure advance M572 D0 S0.05 ; BLTouch - Heaters M307 H3 A-1 C-1 D-1 ; Disable the 2nd Heater to free up PWM channel 1 on the Duex board ; Z-Probe M574 Z1 S2 ; Define Z to use Probe. Home to Min. M558 P9 H5 F100 T2000 ; Set Z probe type/mode 9. G31 P50 X0 Y73.8 Z2.55 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment M557 X0:500 Y0:400 S100 ; define mesh grid ; Heaters M140 H-1 ; Disable heated bed ;M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 ;M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C . ; Fans M106 P0 S0 I0 F600 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; tool 0 uses extruder 0 and heater 1 G10 P0 X0 Y0 Z0 R0 S0 ; set tool 0 offsets and temperatures M501; And I got this in deployprobe.g
M280 P3 S10
And I got this in retractprobe.g
M280 P3 S90
With the duex2 board it worked, now the BLTourch lights up all the time but does not work.
post your config overwrite.
; Heater model parameters M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1 M307 H1 A351.8 C150.9 D9.0 S0.80 V24.4 B0 M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0 M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0 M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0 M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0 M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0 G10 L2 P1 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P2 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P3 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P4 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 U0.00 G10 L2 P9 X0.00 Y0.00 Z0.00 U0.00 -
I had a fualt on my which would not finish self test after rebuilding my hotend mount which I solved by adjusting the grub screw slighty. Worked ever since .
The strange thing is that the red LED lights up all the time, and none of the self test/other commands work. Only thing I did was change from Duex2 to a Duex5.
my bl touch v3.1 was staying red on startup when it could not complete its self test. I thought it was the wiring after moving it upto the printer and extending the cables but they tested ok and after reading someone elses post they mentioned the grub screw which I had not touched. So I gave it a little adjustment turned the printer back on and it completed it self test straight away as normal. Give it a go it might work.
@Javajoeuk Ok! I will test that!
You mean the little screw on the top of the BLTouch right? -
yes be gentle.
@Javajoeuk Tried it with no success, it won't activate for some reason..
Any other idea? -
no sorry
@Phaedrux Do you find anything strange in the config?
can you try a different pwm port?
@Veti Yes of course, which heater do I need to disable if I wan to use PWM_2?
try 5 or 7. they are often used for bltouch
@Haggan90 said in BLtouch does not work after changing to DUEX5 board:
Try disabling heater 7 and use PWM5 on the DueX, that's a common combination.
@dc42 Thank you, I will try that!
@dc42 said in BLtouch does not work after changing to DUEX5 board:
Do I need to change anything more then this: M307 H7 A-1 C-1 D-1 ?
And remove the M307 from config-override.g -
You'll also have to update your deploy and retract macros to reference the new pin number as well.
