    BLtouch does not work after changing to DUEX5 board
    2.2k
    • Haggan90undefined
      Haggan90 @Javajoeuk
      @Javajoeuk Ok! I will test that!
      You mean the little screw on the top of the BLTouch right?
      • Javajoeukundefined
        Javajoeuk
        yes be gentle.
        Haggan90undefined 1 Reply Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @Javajoeuk
          @Javajoeuk Tried it with no success, it won't activate for some reason..
          Any other idea? 😃
            Javajoeuk
            no sorry
            • Haggan90undefined
              Haggan90 @Phaedrux
              @Phaedrux Do you find anything strange in the config?
              • Vetiundefined
                Veti
                can you try a different pwm port?
                • Haggan90undefined
                  Haggan90 @Veti
                  @Veti Yes of course, which heater do I need to disable if I wan to use PWM_2?
                  • Vetiundefined
                    Veti
                    try 5 or 7. they are often used for bltouch
                      dc42 administrators @Haggan90
                      @Haggan90 said in BLtouch does not work after changing to DUEX5 board:
                      Try disabling heater 7 and use PWM5 on the DueX, that's a common combination.
                      Haggan90undefined 2 Replies Last reply Reply Quote 0
                      • Haggan90undefined
                        Haggan90 @dc42
                        @dc42 Thank you, I will try that!
                        • Haggan90undefined
                          Haggan90 @dc42
                          @dc42 said in BLtouch does not work after changing to DUEX5 board:
                          Do I need to change anything more then this: M307 H7 A-1 C-1 D-1 ?
                          And remove the M307 from config-override.g
                            You'll also have to update your deploy and retract macros to reference the new pin number as well.
                            • Haggan90undefined
                              Haggan90 @Phaedrux
                              @Phaedrux Should that be M280 P5 S10 then?
                                P7 for heater pin 7
                                By the way using pins gets a lot easier in RRF3. Might be time to consider updating.
                                • Haggan90undefined
                                  Haggan90 @Phaedrux
                                  @Phaedrux Right now I just want the printer to work again, been down for almost a year now 😕
                                  Changing to heater 7 did not work, still the same problem..
                                    Please post the current version of your config.g, config-override.g, deploy and retract macros, and please double check which pin you're connected to. And refresh me on which wires are going where.
                                    • Haggan90undefined
                                      Haggan90 @Phaedrux
                                      @Phaedrux Ok!
                                      Config.g
                                      G21												; work in millimeters
                                      G90                                             ; Send absolute coordinates...
                                      M83                                             ; ...but relative extruder moves
                                      M552 S1                                         ; Enable network
                                      M586 P0 S1                                      ; Enable HTTP
                                      M586 P1 S0                                      ; Disable FTP
                                      M586 P2 S0                                      ; Disable Telnet
                                      M584 X6 Y1 Z2:5:4 E3							; set 3 Z drivers
                                      M569 P1 S0                                      ; Drive 1 goes backwards
                                      M569 P2 S0                                      ; Drive 2 goes backwards
                                      M569 P3 S1                                      ; Drive 3 goes forwards
                                      M569 P4 S1                                      ; Drive 4 goes forwards
                                      M569 P5 S0                                      ; Drive 5 goes backwards
                                      M569 P6 S1                                      ; Drive 6 goes forwards
                                      M669 K0 Y-1.005:1:0:							; set Y to react with X
                                      ; Defining X and Y coordinates of the leadscrews
                                      M671 X-80:580:580 Y245:490:0 S5 				; leadscrews at front right, rear right and middle left
                                      M350 U16 X16 Y16 E16 Z16 I1                    	; Configure microstepping with interpolation
                                      M92  X133.33 Y242.00 Z200 E415.00      			; Set steps per mm
                                      M566 X900.00 Y900.00 Z20.00 E200.00		     	; Set maximum instantaneous speed changes (mm/min)
                                      M203 X15000.00 Y15000.00 Z600.00 E3600.00		; Set maximum speeds (mm/min)
                                      M201 X1000.00 Y1000.00 Z30.00 E3000		     	; Set accelerations (mm/s^2)
                                      M906 X1000.00 Y1500.00 Z1000.00 E700.00 I30 	; Set motor currents (mA) and motor idle factor in per cent
                                      M84 S30                                         ; Set idle timeout
                                      ;Energize Z steppers
                                      M906 I100 										; prevent idle current reduction
                                      G91 											; relative mode
                                      G1 S2 Z0.1 										; energize all 3 motors
                                      G90 											; absolute mode
                                      M208 X0 Y0 Z0 S1                       	 		; Set axis minima
                                      M208 X500 Y500 Z750 S0                 			; Set axis maxima
                                      M574 X1 S0										; Set active low endstops
                                      M574 Y2 S1                               		; Set active high endstops
                                      ; Pressure advance
                                      M572 D0 S0.05
                                      ; BLTouch - Heaters
                                      M307 H7 A-1 C-1 D-1 							; Disable the Heater7 to free up PWM channel 5 on the Duex board
                                      M574 Z1 S2 										; Define Z to use Probe. Home to Min.
                                      M558 P9 H5 F100 T2000							; Set Z probe type/mode 9.
                                      G31 P50 X0 Y73.8 Z2.55							; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                      M557 X0:500 Y0:400 S100							; define mesh grid
                                      M140 H-1 					; Disable heated bed
                                      ;M305 P0 T100000 B4138 R4700                    ; Set thermistor + ADC parameters for heater 0
                                      ;M143 H0 S120                                   ; Set temperature limit for heater 0 to 120C
                                      M305 P1 T100000 B4138 R4700                     ; Set thermistor + ADC parameters for heater 1
                                      M143 H1 S280                                   	; Set temperature limit for heater 1 to 280C
                                      M106 P0 S0 I0 F600 H-1                        	; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M106 P1 S1 I0 F500 H1 T45                       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                      M563 P0 D0 H1 F0                                ; tool 0 uses extruder 0 and heater 1
                                      G10 P0 X0 Y0 Z0 R0 S0                           ; set tool 0 offsets and temperatures
                                      M501;
                                      Config-override.g
                                      0:/sys/config-override.g
                                      ; config-override.g file generated in response to M500
                                      ; Heater model parameters
                                      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                      M307 H1 A351.8 C150.9 D9.0 S0.80 V24.4 B0
                                      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      G10 L2 P1 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P2 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P3 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P4 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P5 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P6 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P7 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P8 X0.00 Y0.00 Z0.00 U0.00
                                      G10 L2 P9 X0.00 Y0.00 Z0.00 U0.00
                                      My Duet
                                      Send code...
                                      Status
                                      Idle
                                      Tool Position
                                      X
                                      0.0
                                      Y
                                      0.0
                                      Z
                                      0.10
                                      Extruder Drives
                                      Drive 0
                                      0.0
                                      Speeds
                                      Requested Speed
                                      0 mm/s
                                      Top Speed
                                      0 mm/s
                                      Sensors
                                      Vin
                                      24.5 V
                                      MCU Temperature
                                      33.2 C
                                      Fan RPM
                                      0
                                      Z-Probe
                                      0
                                       Tools
                                       Extra
                                       Control All
                                      Tool	Heater	Current	Active	Standby
                                      Tool 0
                                      T0 - Load Filament	Heater 1
                                      off	22.1 C
                                      0
                                      0
                                      Temperature Chart
                                      System Directory
                                      deploy
                                      ; deployprobe.g
                                      ; called to deploy a physical Z probe
                                      ; generated by RepRapFirmware Configuration Tool v2 on Tue Nov 20 2018 21:58:16 GMT+0100 (centraleuropeisk normaltid)
                                      M280 P7 S10
                                      Retract
                                      ; retractprobe.g
                                      ; called to retract a physical Z probe
                                      M280 P7 S90
                                        Does the BLTouch do a self test at power on?
                                        Does sending M401 and M402 deploy and retract the pin?
                                        • Haggan90undefined
                                          Haggan90 @Phaedrux
                                          @Phaedrux said in BLtouch does not work after changing to DUEX5 board:
                                          No it does not.
                                          Nothing hapends at all.. The bltouch just lights constantly red.
                                          • Haggan90undefined
                                            Haggan90
                                            This is my M122
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
                                            Board ID: 08DGM-956GU-DJMSJ-6JTDD-3S86L-1APHG
                                            Used output buffers: 3 of 24 (20 max)
                                            Static ram: 25712
                                            Dynamic ram: 93624 of which 0 recycled
                                            Exception stack ram used: 296
                                            Never used ram: 11440
                                            Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3736) IDLE(ready,160)
                                            Owned mutexes:
                                            Last reset 00:18:03 ago, cause: power up
                                            Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11400 bytes (slot 2)
                                            Error status: 0
                                            Free file entries: 10
                                            SD card longest block write time: 18.2ms, max retries 0
                                            MCU temperature: min 26.5, current 35.2, max 35.5
                                            Supply voltage: min 24.3, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 5: standstill, SG min/max not available
                                            Driver 6: standstill, SG min/max not available
                                            Driver 7: standstill, SG min/max not available
                                            Date/time: 2021-01-19 20:58:36
                                            Cache data hit count 3312721499
                                            Slowest loop: 35.52ms; fastest: 0.07ms
                                            Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 162ms
                                            === DDARing ===
                                            Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                            Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                                            Segments left: 0
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is idle in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 102.91ms; fastest: 0.00ms
                                            HTTP sessions: 1 of 8
                                            - WiFi -
                                            Network state is running
                                            WiFi firmware version 1.23
                                            WiFi MAC address bc:dd:c2:53:09:3f
                                            WiFi Vcc 3.32, reset reason Turned on by main processor
                                            WiFi flash size 4194304, free heap 25824
                                            WiFi IP address 192.168.1.214
                                            WiFi signal strength -78dBm, reconnections 0, sleep mode modem
