    DWC RRF3.2 - can't download macro folder using zip functionality
    Duet Web Control
    87
    • lael
      lael last edited by
      I just updated to RRF3.2 a couple of days ago. I'm working on the macro organisation and design for the printer and wanted to download the entire folder as a zip file, similar to how you would for the system folder - right click - download as zip. However the option is not showing up in the macros folder. Is there something I'm missing / some other way to do it?
      • fcwilt
        fcwilt last edited by
        Have you selected all the macros you want to ZIP and download?
        • lael
          lael last edited by
          Yes. I just checked after your comment - it seems it doesn't offer a zip option if there are folders selected, but does offer zip if there are only files selected. I wonder if this is the intended functionality? Sure would be helpful to be able to download the entire root directory.
          fcwilt 1 Reply Last reply Reply Quote 0
            It won't work with subfolders at the moment. The best options are either pull the SD card and copy, or setup an FTP client and download them that way.
            lael 1 Reply Last reply Reply Quote 0
            • fcwilt
              fcwilt @lael last edited by
              @lael said in DWC RRF3.2 - can't download macro folder using zip functionality:
              I see.
              I've never created any sub-folders so I never noticed this.
              • lael
                lael @Phaedrux last edited by
                @Phaedrux said in DWC RRF3.2 - can't download macro folder using zip functionality:
                Is there a guide you would recommend for setting up FTP access?
                  There's not a lot to it really. You enable FTP access in config.g and then use something like filezilla to connect to the IP address of the duet.
                  Filezilla settings from what I recall.
                  Tab General: Encryption - Only use plain FTP (insecure)
                  Tab General: Logon Type - Anonymous
                  Tab Advanced: Server Type - Default
                  Tab Tranfer Setting: Tranfer Mode - Passive
                  There's also these two options: https://forum.duet3d.com/topic/20979/any-way-to-easily-backup-files?_=1611036017982
                  • lael
                    lael last edited by
                    @Phaedrux Thanks for the redirect to https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor - It's really good. I added a post with some more explanation than the readme gives to help others get started a little quicker.
