    I cant use usbdisk at v3.2&pi
    • huai3895undefined
      huai3895
      I choose ''sd card 2''in ''jobs'', it used to read the USB stick on the raspberry
      But when i update to3.2 rc2 and update duetpi,i cant read stick now,the web control show me "faild to get file list,driectory 2not found"
      I have try "sudo gpasswd -a dsf disk"or"sudo gpasswd -a dsf pi" and restart ,still faild.
      QAQ ,is it has any way to fix that?
        You should be fully updated to 3.2 final now, not RC2.
        Does the usb stick work in a pc?
        huai3895undefined 1 Reply Last reply Reply Quote 0
        • huai3895undefined
          huai3895 @Phaedrux
          @Phaedrux I updare to3.2fimal now,still cant fix that ,i think the promble up to duetpi but not duet3,and the disk can work normal at pc&raspie,i can put f11 to shut down webcontrol on duetpi , then i can see the disk on desktop and open it normal.
          • chrishammundefined
            chrishamm administrators
            You must configure your auto-mount utility to grant read access to the dsf user and/or group. How do you auto-mount USB drives?
            Duet software engineer
            • huai3895undefined
              huai3895 @chrishamm
              @chrishamm I dont know how to configure auto-mount utility😧 ,i only try try "sudo gpasswd -a dsf disk"or"sudo gpasswd -a dsf pi.
