    Set up three Z-axis location - M671
    79
    • bernie-mix
      bernie-mix last edited by
      Hey guys,
      Set up three Z-axis location - M671- in RRF3 on Duet 3 MB6HC:
      Which coordinates should I enter? The real ones of the leadscrews (A) or the ones where the bed actually rests (B)?
      • fcwilt
        fcwilt last edited by
        In theory the B locations are the best.
        But during testing I have tried both A and B locations with equivalent results.
          If it's a properly designed kinematic mount where the center of rotation is at the contact point between the mount and bed, use B. If it's a more rigid bed mount use A because the point of rotation is likely going to be closer to the point of force.
          • bernie-mix
            Yes, it is a kinematic mount with ball screws. According to my logic, I wanted to use the "B" position too. Many thanks for your help
            fcwilt 1 Reply Last reply Reply Quote 2
            • fcwilt
              fcwilt @bernie-mix last edited by
              @bernie-mix said in Set up three Z-axis location - M671:
              What rests on the balls?
              On my printer the left and right are v-groves and the rear is a simple spherical recess.
              Thanks.
              • bernie-mix
                At the rear is a magnetic spherical recess, front right is magnetic v-groves (45° to X and Y axis) and front left a a plane round magnet
                fcwilt 1 Reply Last reply Reply Quote 1
                • fcwilt
                  How did you chose that arrangement? I found that the two front points could use the same approach.
                  Thanks.
                  bernie-mix 1 Reply Last reply Reply Quote 0
                  • bernie-mix
                    bernie-mix @fcwilt last edited by bernie-mix
                    @fcwilt
                    In my opinion, this is the only way the bed can expand in all directions without rotating around the spherical recess
                    fcwilt 1 Reply Last reply Reply Quote 0
                    • fcwilt
                      @fcwilt
                      Ah... So the balls are lifting the heated bed itself? If so I can understand your arrangement.
                      Thanks.
